Subinterfaces will not come up on 1921
clybumat1
Level 3
Level 3
I'm thinking I'm missing something simple here.  I'm trying to create subinterfaces on a 1921 for a test lab.  Whenever I create one, it is in admin down and will not come up when doing a no shut
Example:
interface GigabitEthernet0/1.1
description HOME
encapsulation dot1Q 1 native
Notice it does not show that its shutdown.  But when I view the interface itself, its admin down:
Router#sh int gi0/1.1
GigabitEthernet0/1.1 is administratively down, line protocol is down
Also:
Router#sh ip int brief
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/1.1 192.168.1.1 YES manual administratively down down
Any ideas of what I'm missing here?
Hi @clybumat1 ,
If the switch is connected to the router interface g0/0, then the subinterface must be g0/0.1
If you only use vlan 1, the subinterface is not necessary, since the router interfaces traffic by that vlan by default. If you are going to use another vlan number or more than one, then you need the subinterfaces.
Within the subinterfaces you must enter these commands:
encapsulation dot1q <vlan number>
ip address <ip> <mask>
12 Replies 12
luis_cordova
Hi @clybumat1 ,
Query: Did you enter the no shutdown command in the g0/1 interface?
The main interface must be UP so that all sub-interfaces are as well.
0/0 goes to a switch.  Both 0/0 and 0/1 are unshut.
Hi @clybumat1 ,
could you share the result of the show running-config command?
Both your router and the switch that is connected to the g0 / 1 interface.
The switch is actually connected to 0/0
Router#sh run
Building configuration...
Current configuration : 1230 bytes
! Last configuration change at 21:12:01 UTC Thu Apr 18 2019
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX18048326
vtp mode transparent
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Uplink to switch
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
description HOME
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
no vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input telnet
transport output telnet
scheduler allocate 20000 1000
end
Switch:
witch#sh run
Current configuration : 920 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable secret 5 $1$i4m8$FiqkcfIn1y2KHvSGT/Jxa0
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
description Uplink to Router
switchport mode trunk
interface Vlan1
description #HOME#
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
Hi @clybumat1 ,
Changing the sub interface to gi0/0.1 did the trick. Thanks for your help!
balaji.bandi
GigabitEthernet0/0 unassigned YES NVRAM up up    < -- your main interface up.
GigabitEthernet0/1 unassigned YES NVRAM administratively   down down   <-- go to sub interface unshut
GigabitEthernet0/1.1 192.168.1.1 YES manual administratively down down <-- go to sub interface unshut
BB
Yes that is what I have tried.  I go to unshut the sub interface and and still stays admin down..
Can you post full config of both the side ? of the device please to verify.
BB
Yes and good catch
may be you looking to subinterface G0/0 not G0/1 - I guess ?
BB
I am not clear on what you have physically connected to GigabitEthernet0/1...GigabitEthernet0/0 goes to the switch, what does GigabitEthernet0/1 go to ?
This is a bug, you need add "no ip address" under physical interface.
