subneting
cisco steps
Level 7
Level 7
can anyone provide me w/ subneting tips and so .. I do know my way around the sw and rt but, I could not master the subneting, anytime there is a senario I struggle..:-( pls help
cowetacoit
Level 7
Level 7
http://www.learntosubnet.com/
This should be all of the information your are looking for. rate if helpful.
cowetacoit
Level 7
Level 7
I'll rate you cowetacoit. I used http://www.learntosubnet.com/ when learning subnetting. Great learning source!
Garry
Yes it is very helpful. The good think is once you finally learn it you won't forget it.
