Supervisor Engine for Cisco 4003 Switch
anden4380
Hey
i need help i have buy a Cisco 4003 Switch whit Supervisor Engine I but it only run CatOs and i whant it to run Cisco IOS so whitch Supervisor Engine can the Cisco 4003 Switch run? i have look at the Supervisor Engine III it can run Cisco IOS and Layer 3 but can i use that in my Cisco 4003 switch?
Thanks for your help
Anders
15 Replies 15
This is a really simple answer, you don't need links or Cisco white papers, and it is all based upon the physical design of the PCB edge connector of the supervisor engine. Anything beyond a supervisor engine I will NOT even fit into the 4003 switch. The multipin PCB connector (white) on the SUP I is thinner (less pins) than the multipin PCB connector on Sup II thru IV. You would need a billy club to make a Sup II or above fit into a 4003 switch.
