Switch 3560 not giving out power
edithflore
I have an issue with a 3560 in my network, after sometimes it fails to give out power to some ip phones,while others are not affected and below is the message i get
"Power given, but Power Controller does not report Power Good"
output of sh power inline and sh env all : everything seems to be ok on the switch
#sh power  inline
Available:450.0(w)  Used:48.0(w)  Remaining:402.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/1     auto   off        0.0     n/a                 n/a   15.4
Gi0/2     auto   off        0.0     n/a                 n/a   15.4
Gi0/3     auto   off        0.0     n/a                 n/a   15.4
Gi0/4     auto   off        0.0     n/a                 n/a   15.4
Gi0/5     auto   off        0.0     n/a                 n/a   15.4
Gi0/6     auto   on         9.6     AIR-AP1131AG-E-K9   3     15.4
Gi0/7     auto   on         9.6     IP Phone 7940       n/a   15.4
Gi0/8     auto   off        0.0     n/a                 n/a   15.4
Gi0/9     auto   off        0.0     n/a                 n/a   15.4
Gi0/10    auto   off        0.0     n/a                 n/a   15.4
Gi0/11    auto   on         9.6     IP Phone 7941       2     15.4
Gi0/12    auto   off        0.0     n/a                 n/a   15.4
Gi0/13    auto   off        0.0     n/a                 n/a   15.4
Gi0/14    auto   off        0.0     n/a                 n/a   15.4
Gi0/15    auto   off        0.0     n/a                 n/a   15.4
Gi0/16    auto   off        0.0     n/a                 n/a   15.4
Gi0/17    auto   on         9.6     IP Phone 7961       2     15.4
Gi0/18    auto   on         9.6     IP Phone 7975       3     15.4
Gi0/19    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Gi0/20    auto   off        0.0     n/a                 n/a   15.4
Gi0/21    auto   off        0.0     n/a                 n/a   15.4
Gi0/22    auto   off        0.0     n/a                 n/a   15.4
Gi0/23    auto   off        0.0     n/a                 n/a   15.4
Gi0/24    auto   off        0.0     n/a                 n/a   15.4
#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 18 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 49 Degree Celsius
Red Threshold    : 59 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  C3K-PWR-750WAC      DTN1233E1KB  OK              Good     Good     300/450
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   <>              <>
It's solved by a reboot of the switch, i need your assistance to know what exactly is wrong and how solve this issue once for good, i could have suspected a power environnment issue but it's the only equipement disturbing in the network.
20 Replies 20
The result of the TDR tests after the reload is worst.  That's the bad news.  Here's the good news:  Look at the "distance".  Change the patch cables directly connected to the switch.  Maybe that's the reason.
12.2.35 SE is years old at this point, you should think about upgrading to something newer if you are still having problems.
I agree Glenn.
I did an upgrade of the IOS, it seems to be ok... am observing
nnnnd Thanks a lot leolaohoo for the document, it's really helpful.
Glad to be of some kind of assistance.
Hi Edithflore,
     I want to know if the upgrade worked well. We have a similar situation, we just reloaded the switch and the issue got fixed.  It would be better do an upgrade or required an RMA for the device.
P.S. This switch is in a Stack with two others and its the only one showing this problem.
