Switch 3560 not giving out power
edithflore
I have an issue with a 3560 in my network, after sometimes it fails to give out power to some ip phones,while others are not affected and below is the message i get
"Power given, but Power Controller does not report Power Good"
output of sh power inline and sh env all : everything seems to be ok on the switch
#sh power  inline
Available:450.0(w)  Used:48.0(w)  Remaining:402.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/1     auto   off        0.0     n/a                 n/a   15.4
Gi0/2     auto   off        0.0     n/a                 n/a   15.4
Gi0/3     auto   off        0.0     n/a                 n/a   15.4
Gi0/4     auto   off        0.0     n/a                 n/a   15.4
Gi0/5     auto   off        0.0     n/a                 n/a   15.4
Gi0/6     auto   on         9.6     AIR-AP1131AG-E-K9   3     15.4
Gi0/7     auto   on         9.6     IP Phone 7940       n/a   15.4
Gi0/8     auto   off        0.0     n/a                 n/a   15.4
Gi0/9     auto   off        0.0     n/a                 n/a   15.4
Gi0/10    auto   off        0.0     n/a                 n/a   15.4
Gi0/11    auto   on         9.6     IP Phone 7941       2     15.4
Gi0/12    auto   off        0.0     n/a                 n/a   15.4
Gi0/13    auto   off        0.0     n/a                 n/a   15.4
Gi0/14    auto   off        0.0     n/a                 n/a   15.4
Gi0/15    auto   off        0.0     n/a                 n/a   15.4
Gi0/16    auto   off        0.0     n/a                 n/a   15.4
Gi0/17    auto   on         9.6     IP Phone 7961       2     15.4
Gi0/18    auto   on         9.6     IP Phone 7975       3     15.4
Gi0/19    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Gi0/20    auto   off        0.0     n/a                 n/a   15.4
Gi0/21    auto   off        0.0     n/a                 n/a   15.4
Gi0/22    auto   off        0.0     n/a                 n/a   15.4
Gi0/23    auto   off        0.0     n/a                 n/a   15.4
Gi0/24    auto   off        0.0     n/a                 n/a   15.4
#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 18 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 49 Degree Celsius
Red Threshold    : 59 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  C3K-PWR-750WAC      DTN1233E1KB  OK              Good     Good     300/450
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   <>              <>
It's solved by a reboot of the switch, i need your assistance to know what exactly is wrong and how solve this issue once for good, i could have suspected a power environnment issue but it's the only equipement disturbing in the network.
20 Replies 20
Leo Laohoo
What IOS are you running?
Can you do the following:
1.  Command:  test cable tdr int ;
2.  Wait for about 5 to 7 seconds;
3.  Command:  sh cable tdr int ; and
4.  Post the complete output please.
below the ouput for 2 ports
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/2     auto  Pair A     38   +/- 1  meters N/A         Short/Impedance Mism
                Pair B     42   +/- 1  meters N/A         Open
                Pair C     38   +/- 1  meters N/A         Short/Impedance Mism
                Pair D     48   +/- 1  meters N/A         Short/Impedance Mism
TDR test last run on: September 28 08:47:45
Gi0/17    auto  Pair A     149  +/- 1  meters N/A         Normal
                Pair B     151  +/- 1  meters N/A         Normal
                Pair C     35   +/- 1  meters N/A         Short/Impedance Mism
                Pair D     21   +/- 1  meters N/A         Short/Impedance Mism
The strange thing is, even when the phone is directly connected to the switch it still doesn't work unless I reboot the switch
Did you tried in any other port? What was the result?
Regrads,
Sunil
Regards, Sunil Khanna
I've tried but it doesn't work until i reboot the switch
2011/9/28 sunkhann
Cisco Support Community <> Re: Switch 3560 not giving out power created by Sunil
Khanna <> in *LAN,
Switching and Routing* - View the full discussion<>
ankugarg
Level 3
Level 3
I have seen this message sometimes..It generally happens when switch boots up and all the devices request for power together...Mostly reload of the box solves the issue
and the IOS version is  Version 12.2(35)SE5
Sorry Ankur.  I will have to disagree with you on this as I see this on a daily basis.
The TDR result is very "accurate".  Pair C and D both shows signs of bad cabling.
Pair C controls PoE and Pair D controls GigabitEthernet.
The error message of "Short/Impedance Mism" is not good.  A good result to a patched outlet is "Normal".
Another thing:  Take a look at the distance of Pairs A & B.  This figure is not THAT accurate but it does give me a worry that the cabling at the far end could be faulty or the patch port at the far-end could be faulty.
NOTE:  Whoever thought about putting a TDR into the switches deserve a raise.  You have no idea how much money we saved with this function.
Hey,thanks leolaohoo for correction...I also face these issues regularly..Can you refer to any document which tells how to debug them,ot has more info on above commands ?
How about writing a blog article on this troubleshooting ?
To be honest with you, the Cisco documents for the TDR is very, very vague.  My experience with this feature has all been through trial-and-error.  If I publish a "blog", is there a way for the document be vetted and the original document be improved or updated?
Hey Ankur,
I've finished a Guide.  I'm going to submit the docu to the NetPro/CSC administrator for approval.
Hey thanks a lot..Thats very useful document..I'm in the process of trying somethings from your document..Will get back in documents section..Thanks again
Hi Ankur,
Please provide feedback so I can improve the document.
Reloading the switch frequently is my real issue,
Have a look a this test, i connected the phone directly to the switch with a pretested cable, does the result below shows that the ports have issues ?
TDR test last run on: September 28 09:49:33
Gi0/20    auto  Pair A     2    +/- 1  meters N/A         Short/Impedance Mism
                Pair B     2    +/- 1  meters N/A         Open
                Pair C     9    +/- 1  meters N/A         Short/Impedance Mism
voice-data-3560-yde#
TDR test last run on: September 28 09:51:21
Gi0/22    auto  Pair A     2    +/- 1  meters N/A         Open
                Pair B     2    +/- 1  meters N/A          Short/Impedance Mism
                Pair C     11   +/- 1  meters N/A         Short/Impedance Mism
                Pair D     6    +/- 1  meters N/A         Short/Impedance Mism
