switch 3560e not loading IOS
Roldan
Hi everyone:
I am trying to have a switch working(some one gave it to me as a gift, is a used switch but it was working). due to their company rules they deleted it before they gave it away.
I just want it to hard reset it so i can practice for my CCNA, but i fall into the below issues:
when i connect trough console it shows the below:
Switch:
when i try to reboot
switch: boot
Loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"...flash:c3560e-universalk9-m
z.150-2.SE8.bin: invalid argument
Error loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
so i think that, c3560e-universalk9........ IOS was the one installed before, but i can not download that one so
i downloaded from cisco "c3560e-ipbasek9-mz.122-55.SE12.bin" to try to install that one instead(maybe is not the correct one, i am new in this)
but xmodem does not work, veryfied already the settings to 9600 b/p/s.
got after a few seconds a pop-up window that states "no response from remote system"
I check the flash and the below is shown:
switch: dir flash:
Directory of flash:/
2 -rwx 2282 <date> config.text
3 -rwx 5 <date> private-config.text
4 -rwx 3096 <date> multiple-fs
57662464 bytes available (9216 bytes used)
Can you please help me? i might be doing something wrong.
also the below is the version if it helps in any way.
switch: version
C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
Compiled Tue 27-Nov-12 00:23 by abhakat
Thank you all in advance.
16 Replies 16
Gald it worked the solutuobn and good to hear all good. if the issue was resolved mark as resolved/solution so it will be usefull for other community members.
BB
The USB used is not supported. Find another brand.
