switch: CCCCCCCCCCxmodem:: I/O error
Steve Coady
Level 7
Level 7
hello
I goofed and uploaded a new image to my Cisco 3750.
I deleted the prior image and set the boot flash statement and then used the command boot system flash: old image/new image
This caused me to enter into switch: mode
I have tried various recovery steps
   flash_init
    load_helper
The dir flash still show old image which was deleted. It seemed my only course to reciver was to Xmodem
I am using SecureCRT and tried the TRANSFER XMODEM option, no success
I then issued the following (twice:
switch: copy xmodem: flash:c3750-ipservicesk9-mz.122-55.SE9.bin
Begin the Xmodem or Xmodem-1K transfer now...
switch:
What other options can I try to correct this mistake?
sMc
2 Accepted Solutions
Run your command, using SecureCRT. Then, BEFORE the 3rd C appears complete the following steps in SecureCRT...
  • Go to Transfer -> Send Xmodem.
  • Choose your file and hit OK
should run fine after that. I'm curious to know what BAUD rate you're using...
I see that your baud is set to 9600.
BAUD=9600
Did you just set that per my instructions above?  I was able to find a step by step guide on Cisco (if you don't have it already).  Shows how to do the upload in either baud rate.  Keep in mind that in your case you'd use the Transfer -> Send xmodem option in SecureCRT vs what you'd do in HyperTerminal:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html#speedrecovery
32 Replies 32
InayathUlla Sharieff
switch:dir flash:
switch:flash_init
Switch:load-helper
Switch:boot flash:filename/filename
2)
Try using the Hyperterminal :
I am using HT to copy files using xmodem, and it works fine with baud rate set to 115200.
For this to work, you have first ensure that there's enough free space on the flash (if not, format it or delete files). Then you have to execute "set BAUD 115200". Once you press Enter console will stop responding. You will have to disconnect (Call -> Disconnect), then change connection Properties (File -> Properties -> Configure) and set HyperTerminal connection's baud rate to 115200. You will have your connection restored.
After this just execute "copy xmodem: flash:.bin" and start file transfer in HT (Transfer -> Send File). Ensure that you selected an appropriate BIN  file and changed transfer mode to XMODEM or XMODEM-1K before pressing send.
Insharie
Thank you for the response. I am on windows 7, No Hyperterm. SecureCRT and putty are my options.
There is enough free space.
Still unable to get this done.
sMc
Antonio
Here is what I have entered
CCC
Starting xmodem transfer.  Press Ctrl+C to cancel.
Transferring c3750-ipservicesk9-mz.122-55.SE9.bin...
I do not see anything showing a transfer in progress, is that  expected
sMc
Typically, no.  You'd have CCCCCC................. and the ....  output continues till the transfer was completed.  If you lost the console connection the moment you hit enter and can't do anything at that point, change your baud rate reconnect and restart xmodem transfer.  If yours is 9600, change it to 115200 and reconnect then restart xmodem transfer in SecureCRT.  If yours is already 115200, change it back to 9600 and reconnect then restart Xmodem transfer in SecureCRT.
Please rate if helpful
Antonio
I must have lost connection, however, both the switch and COM port show 115200
switch: flash_init
Initializing Flash...
...The flash is already initialized.
Setting console baud rate to 115200...
My COM 3 port is also set to 115200.
after the process shows "Transferring c3750-ipservicesk9-mz.122-55.SE9.bin..." nothing else happens
sMc
at the switch: prompt, type 'set' and hit Enter.  Post the output here so we can check settings.
Antonio
switch: set
$=!ýßúKõ˜ž÷ãÐHbŒ›ˆ}.Ý·!á,CÏÚ¿ÇÄŠO\Àíb¾€ýãëb'O]FBó_Åû¶:ÆÙÃEu­@y˜h>º?:.ìÍÏ÷”¡—Øç©ë&ªºû"->¿±“—‡/4›½ÅǪøš¯§ª+&žö¥‰†¶4+»
>Z=ç-î-Œ}üOµè%S.        ïñª& CPËX³J~V¯3
BAUD=9600
BOOT=f+a_h:/c3750-i-_e_+ice_+9-+z.122-55.SE9.bi+
CLEI_CODE_NUMBER=CNMWU00ARC
MAC_ADDR=00:19:E7:72:7E:80
MODEL_NUM=WS-C3750G-48TS-S
MODEL_REVISION_NUM=D0
MOTHERBOARD_ASSEMBLY_NUM=73-10218-08
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FOC10414HSM
POWER_SUPPLY_PART_NUM=341-0107-01
POWER_SUPPLY_SERIAL_NUM=AZS104508DE
SDM_TEMPLATE_ID=0
SWITCH_NUMBER=2
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FOC1042Y1BK
TAN_NUM=800-26857-01
TAN_REVISION_NUMBER=A0
VERSION_ID=V03
 -- MORE --
_+i+ch:
sMc
BAUD=9600
I also notice that there's a bit of gibberish in your output.  You should check your SecureCRT settings and make sure your connection is using the following (attached):
Antonio
settings are the same
sMc
Antonio
Got iot working. Thank you again for the great guidance!
sMc
No problem.  Which solution was the fix?
I changed the BAUD rates to see what might work
I have tried 9600 to 9600 and 115200-115200, same result.
sMc
