Switch logon question
Andy White
Level 7
Level 7
I've configured this in the past where you have 2 users on a switch with different privileges:
username admin privilege 15 secret 5 $1$xhbN$3KuZkWG81
username users privilege 3 secret 5 $1$fW/K$I2fQEJRd7s5
When either account is used normally I would be put into privilege mode 15 or 3 and no need for the enable password.  At the moment i go into user exec mode on each (priv 1).
My VTY lines are like this:
line con 0
exec-timeout 60 0
logging synchronous
line vty 0 4
access-class 23 in
exec-timeout 60 0
logging synchronous
transport input ssh
line vty 5 15
access-class 23 in
no exec
transport input ssh
How can I get each user to go into their respective privilege views without the need for an enable passowrd?
Edison Ortiz
Do you have aaa-new model enabled?
If you don't, you need to add login local under the VTY lines.
If you have aaa-new model enabled, you need to add aaa authorization exec default local
I'm assuming these devices are not pointing to a AAA server?
Edison Ortiz
Great! that worked, silly me.
Hi Andy ,
Do you have aaa configured ?
Dan
