syslog on Nexus 5500 series
Ben Alex
Hi:
My syslog server is not receiving any log. Locally I can see the log.
Here is my config:
logging logfile customer1 6 size 65536
logging server 10.10.10.10 6 use-vrf default
logging timestamp milliseconds
I can ping the server from the nexus.
5 Replies 5
andrew.prince
Level 10
Level 10
Have you read the below
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/sm_syslog.html
Yes I certainly did.
Are you using N5500 with the L3 features? Or L2 only?
Can you post the output of the following commands:
show ip int br
show ip int br vrf management
jerry
Jerry:
Yes it is L3 5596.
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
Vlan400             10.38.107.2    protocol-up/link-up/admin-up
Vlan404             10.18.80.3    protocol-up/link-up/admin-up
Vlan408             10.29.101.2    protocol-up/link-up/admin-up
Vlan412             10.30.100.1    protocol-up/link-up/admin-up
Vlan428             10.39.76.2    protocol-up/link-up/admin-up
Ethernet1/8          172.20.21.1    protocol-up/link-up/admin-up
sh ip int br vrf management
IP Interface Status for VRF "management"(2)
mgmt0                10.0.0.1        protocol-up/link-up/admin-up
Note: I am using default vrf and syslog server is reachable.
Misunderstood you before.
What facility level is configured to receive syslog message on your server? The default for NXOS 5.x software is local7.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/command/reference/rel_5_0/sm_commands.html#wp1237126
jerry
