07-09-2008 05:32 PM - edited 03-06-2019 12:06 AM
I saw this configuration in one of our switch port, but nobody knows why?
interface FastEthernet0/43
switchport access vlan 2
switchport mode trunk
speed 100
duplex full
no cdp enable
end
As far as we know it works as a trunk port, but is there any difference that this could make?
vsubbu
07-09-2008 05:46 PM
Hi Vsubbu,
It is a trunk port . "switchport access vlan 2" will not make any difference.
Saju
07-09-2008 07:14 PM
Usually, the 'access vlan' is entered as a fall-back Vlan in case the trunk fails for some unknown reason.
On this case, you stated the trunk is functional, therefore the command isn't doing anything.
HTH,
__
Edison.
07-10-2008 07:55 AM
Saju & Edison,
Thanks for your comments.
Rgds
vsubbu
