% TDR test is not supported
thefranmaneds
Is there any reason why this command wouldn't work on a 3560 ip-base switch?
C3560-24#test cable-diagnostics tdr interface fastEthernet 0/10
% TDR test is not supported on interface Fa0/10
Here is the config of the interface.
interface FastEthernet0/10
switchport trunk native vlan 7
switchport mode trunk
speed 100
duplex full
srr-queue bandwidth limit 50
7 Replies 7
glen.grant
You can use the TDR feature to diagnose and resolve cabling problems. TDR is supported only on copper Ethernet 10/100/1000 ports. It is not supported on 10/100 ports or small form-factor pluggable (SFP) module ports. For more information about TDR, refer to the software configuration guide for this release.
That is funny I have it running on another 3560 on a FastE port. The main differece is that the switch it works on is running EMI and not SMI
Port Name Status Vlan Duplex Speed Type
Fa0/8 connected trunk a-full a-100 10/100BaseTX
#test cable-diagnostics tdr interface fastEthernet 0/8
Link state may be affected during TDR test
TDR test started on interface Fa0/8
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
sh cable-diagnostics tdr interface fastEthernet 0/8
TDR test last run on: March 04 14:54:44
Interface Speed Local pair Pair length Remote pair Pair status
Fa0/8 100M Pair A 4 +/- 15 meters Pair B Normal
Pair B 4 +/- 15 meters Pair A Normal
Pair C N/A Pair D Not Supported
Pair D N/A Pair C Not Supported
Why would it give you the option for FastE if you can't use it?
#test cable-diagnostics tdr interface ?
FastEthernet FastEthernet IEEE 802.3
GigabitEthernet GigabitEthernet IEEE 802.3z
Anyone????
That is strange. My source came straight from the release notes/command reference. I am surprised that it does work on the EMI image and not the SMI image.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/command/reference/cli3.html#wp2168243
Mark
Mark Yeates
Level 7
Level 7
Kevin,
TDR is supported only on 10/100/1000 copper Ethernet ports. It is not supported on 10/100 ports or on SFP module ports.
HTH,
Mark
What is odd is that does work on 10/100 ports. I though it was the different between SI and EI code but it doesn't seem to be. The switch it is working on is a 3560-8 and we also have a 2960 that it is working on.
2960
Understanding TDR
You can use the Time Domain Reflector (TDR) feature to diagnose and resolve cabling problems. When running TDR, a local device sends a signal through a cable and compares the reflected signal to the initial signal.
TDR is supported only on 10/100 and 10/100/1000 copper Ethernet ports. It is not supported on SFP module ports.
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/swtrbl.html
3560
Understanding TDR
In Cisco IOS Release 12.2(25)SE or later, you can use the Time Domain Reflector (TDR) feature to diagnose and resolve cabling problems. When running TDR, a local device sends a signal through a cable and compares the reflected signal to the initial signal.
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_sed/configuration/guide/swtrbl.html#wp1186482
I'd guess the 3560-8 isn't in the same boat as the rest of the 3560's. It is probably more of a 2960-8 then a 3560.
