telnet issue
gurkamal01
Level 4
Level 4
My question is --
if i am able to telnet to one switch (SW1) from there can i telnet to the other connected switch (SW2) without using an access server 2509 or 2511.
Please help
Edison Ortiz
If the switches have IP reachability and if the vty session and telnet authentication is configured properly, you should be able to hop from one switch to another.
Connecting via the access-server will bring you into the console which often does not require authentication while for telnet session, you do.
Edison
