Timestamp Logging
parklabel
Community Member
The 6509 is not showing timestamps on its logs. It shows the uptime instead.
"service timestamps log datetime localtime" is set. The same goes for debug.
The clock is set on UTC from an NTP server (per policy). Should this make a difference? If not, then what am I missing?
I saw "set logging timestamps" command for 6500 series, but that doesn't work on this IOS version (12.2 (18)), I suppose.
Thanks.
dan-jones
Level 2
Level 2
Have you tried without the 'localtime' option in the service timestamps log? My guess would be the 'clock timezone' might be required for the localtime option to work and its absense is causing issues.
dan-jones
Level 2
Level 2
Edison Ortiz
Are you sure it's logging new entries ?
You can try the following:
no logging buffer
logging buffer
then try to create a logging entry by going into config and type a description under a interface and exit out.
Check the logging buffer then.
Greg
Perhaps we need some clarification: is this 6509 running hybrid mode or native mode? The symptoms sound like it may be running hybrid mode and has service timestamps log set on the MSFC but does not have it set in the SUP.
If that is not the case then perhaps you can post the parts of the config that specify timestamps and examples of the log messages showing uptime (including the first several lines of output from the show log command which show how logging has been configured). Also details of the switch operating environment please.
Rick
Rick
