06-24-2019 09:16 AM
I am trying to connect a 9200 switch stack to our existing 3850 core switch via fiber. I have no idea why, but I am unable to get this to work; I'm getting no blinking lights on either end of the connection.
I am using a 1GB GLC-SX-MMD at both ends of the connection; the 3850 end is connected to GigabitEthernet1/1/2 and the 9200 is connected to TenGigabitEthernet 1/1/1.
I've had the fiber cable checked and it all works fine (SFP ports too) so I'm baffled as to why I cannot get it to work, though it did work when I directly connected the stack master to the 3850.
The configuration on both ports is:
switchport trunk native vlan 105
switchport mode trunk
The transceivers are fine and are detected by both switches and there is nothing else physically wrong so it seems to be a configuration error but I have no idea what.
I don't know where to go next and am very frustrated as to why it's not working.
If anyone can give me some pointers it would be appreciated :)
06-24-2019 10:06 AM
are both interfaces up/up ? Try and swap the transmit/receive ends at one side of the connection (pull the fiber cable out of the transceiver and reinsert it with the tx/rx connectors swapped)...
06-24-2019 11:35 AM
We need more information - when you mentioned not working is that show down/down ?
or any other error ?
make sure you have created VLAN 105 in the Vlan database.
please post
below output to understand the issue
show inter GigabitEthernet1/1/2
show inter tenGigabitEthernet 1/1/1
show run inter tenGigabitEthernet 1/1/1
show run GigabitEthernet 1/1/2
show vlan
06-25-2019 12:42 AM
06-25-2019 07:44 AM
06-25-2019 07:59 AM
Hi all. Apologies for the late response. So I have done some more troubleshooting and the fiber is fine when only one 9200 switch is connected. The moment I added the member switch to the 9200 stack, the connection stopped working.
I now seem to be having difficulty getting the 9200 stack to work. Both stack members have the Cisco IOS XE Software, Version 16.09.03 (Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.9.3
What I did was I connected the stack master to ensure, powered off the member switch, provisioned the member switch, powered on the member switch.
When I do a 'sh ip int brief' it returns the list of ports for both switches, but when I do a 'show switch' I get the following for the member switch:
Switch Role Mac Address Priority H/W version Current State
2 Member 0000.0000.0000 0 Provisioned
I've done a bit of research but have been unable to find anything. Is it a software version issue? Or have I done the steps incorrectly? Appreciate the help as always.
06-25-2019 08:53 AM - edited 06-25-2019 08:55 AM
Hello pinko,
something is not working as the second member is unknown so there is not communication between members.
How have you built the C9200 stack?
are you using the stackwise cables?
what models are you using?
The fixed configuration C9200L support stackwise 80 the C9200 support stackwise 160
see the table in the link below
release notes are here
Hope to help
Giuseppe
06-25-2019 11:29 AM
adding to other post can you post show switch, also give us more information how you have configured this Switch stack.
as per provisioned means :
06-26-2019 12:51 AM
CSCvi56567
