Trying to setup my home lab - Trouble
vidalch63
Im not sure whats going on here ... checked the obvious. Shut, ip space, duplex/speed matc, ip routing isnt on
Reviewing the Config guide for the switch ... Im stumped ....
3550_1#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Vlan1                      192.168.10.3    YES manual up                    up
FastEthernet0/1            unassigned      YES unset  up                     up
FastEthernet0/2            unassigned      YES unset  down                  down
FastEthernet0/3            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  down                  down
3550_1#show cdp nei det
3550_1#
10 Replies 10
And what is the problem?
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
As you can see in my original post,
The link between the 2610 that the 3550 is connect to is up/up across 3550 fa0/1 -> 2610 fa0/0
But I am unable to see cdp info. Although on by default, I when ahead and enable it globally on both devices.
Vlan 1 is also up and I am unable to ping the default gateway.
There is nothing about a 2610 in your original post ...
Paste a "show cdp interface" of both devices and alos the config.
Your original post only shows 3550 information; kind of hard to go by that to help you.
Timers match  ..
Show cdp traffic shows advertisements out both devices
r1 is the 2610xm
3550_1#sh cdp int fa0/1
FastEthernet0/1 is up, line protocol is up
  Encapsulation ARPA
  Sending CDP packets every 60 seconds
  Holdtime is 180 seconds
3550_1#
R1#show cdp interface fa0/0
FastEthernet0/0 is up, line protocol is up
  Encapsulation ARPA
R1#
R1#show cdp traffic
CDP counters :
        Total packets output: 168, Input: 0
        Hdr syntax: 0, Chksum error: 0, Encaps failed: 0
        No memory: 0, Invalid packet: 0, Fragmented: 0
        CDP version 1 advertisements output: 0, Input: 0
        CDP version 2 advertisements output: 168, Input: 0
R1#
3550_1#show cdp traffic
CDP counters :
        Total packets output: 178, Input: 0
        CDP version 2 advertisements output: 178, Input: 0
3550_1#
3550_1#term len 0
3550_1#sh run
Building configuration...
Current configuration : 3804 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3550_1
no logging buffered
enable secret 5 $1$YVCl$zrnwDW1XCNvB5hImIfgQo.
enable password cisco
ip subnet-zero
no ip domain-lookup
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface  FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface  FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface  FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.10.3 255.255.255.192
no ip route-cache
ip default-gateway 192.168.10.1
ip classless
ip http server
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
3550_1#
R1#term len 0
R1#show run
Current configuration : 834 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$FuyJ$wcsePMSmZQSE5rBUIaPfV0
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 192.168.10.1 255.255.255.192
duplex auto
speed auto
interface Serial0/0
description Serial link to R2 router
ip address 192.168.1.1 255.255.255.252
no fair-queue
interface Serial0/1
description Serial link to R3 router
ip address 192.168.2.1 255.255.255.252
ip http server
ip classless
dialer-list 1  protocol ip permit
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R1#
mahmoodmkl
Level 7
Level 7
can u assign the port in vlan 1 on which router is connected
switchport mode access
spanning tree portfast
well i originally configured the 3550 fa0/1
int fa0/1
switchport port-security
switchport port security mac-address wanted to see port security working ...
Once cdp wasnt up, I then configured portfast .. but no change.
just tried it again. No change.
Put switchport mode access on both ports 1and 2. Then plug something up to port 2, then try to ping between the switch and router.
I have fa0/1 and fa0/2 configured as an access port.
fa01 is connected to the 2610 router.
fa0/1 is connect to laptop.
Debug cdp packets shows cdp v2 packets out for fa 1 and 2 on switch.
Debug cdp packets shows cdp v2 packets out for fa 0/0
Neither increment inbout packet counters
