Two Switch Configuration - Four Ports Connect them - Only iSCSI VLAN
webmike10
                   I have two interfaces on multiple servers connecting to two switches for iSCSI traffic only.  I'm not able to ping any interface IP connected to either of the two switches if I do a ping from either switch.  I'm having retransmit errors on the SAN and I think the problem may be in the switch configuration.
Here are my two switch configurations.
I think the problem may be the four switch ports. The 3560-X/T/S has a dedicated management port so instead of vlan 665 I think I may need to replace the VLAN for the uplinks from 665 to 14??
Switch 10
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560X-48       12.2(58)SE2           C3560E-UNIVERSALK9-M
Configuration register is 0xF
------------------ show running-config ------------------
Building configuration...
Current configuration : 12401 bytes
! Last configuration change at 12:16:02 EDT Tue Mar 12 2013 by mike.griffin
! NVRAM config last updated at 13:53:14 EST Fri Mar 8 2013 by mike.griffin
version 12.2
no service pad
service password-encryption
no service dhcp
hostname SWI-10
boot-start-marker
boot-end-marker
no logging console
enable secret 5 <removed>
username privilege 15 secret 5 <removed>
aaa new-model
aaa group server radius RADIUS
server name DC1
server name DC2
aaa authentication login default group RADIUS local-case
aaa authentication login CONSOLE line
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
system mtu routing 9198
ip domain-name .org
vtp mode off
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
port-channel load-balance src-dst-mac
vlan internal allocation policy ascending
vlan dot1q tag native
vlan 14
name iSCSI
vlan 665
name Management
vlan 999
name UNUSED_PORTS
ip ssh source-interface FastEthernet0
ip ssh version 2
interface Port-channel11
description Uplink to SWI-11
switchport access vlan 665
switchport trunk native vlan 665
switchport mode access
switchport nonegotiate
ip flow ingress
ip flow egress
flowcontrol receive on
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
description Management Interface
ip flow ingress
ip flow egress
ip address 10.10.254.10 255.255.255.224
interface GigabitEthernet0/1
description NMS (Gb3)
switchport access vlan 14
ip flow ingress
ip flow egress
flowcontrol receive desired
interface GigabitEthernet0/2
switchport access vlan 999
ip flow ingress
ip flow egress
shutdown
interface GigabitEthernet0/3
description FILE1A (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/4
ip flow ingress
ip flow egress
interface GigabitEthernet0/5
description FILE1A (2-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/6
ip flow ingress
ip flow egress
interface GigabitEthernet0/7
description FILE1B (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/8
ip flow ingress
ip flow egress
interface GigabitEthernet0/9
description FILE1B (2-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/10
ip flow ingress
ip flow egress
interface GigabitEthernet0/11
description SQL2A (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/12
ip flow ingress
ip flow egress
interface GigabitEthernet0/13
description SQL2B (1-0)
ip flow ingress
ip flow egress
down-when-looped
interface GigabitEthernet0/14
ip flow ingress
ip flow egress
interface GigabitEthernet0/15
description MEDIA (Gb3)
ip flow ingress
ip flow egress
interface GigabitEthernet0/16
ip flow ingress
ip flow egress
interface GigabitEthernet0/17
description FILE3A (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/18
ip flow ingress
ip flow egress
interface GigabitEthernet0/19
description FILE3A (2-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/20
ip flow ingress
ip flow egress
interface GigabitEthernet0/21
description FILE3B (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/22
ip flow ingress
ip flow egress
interface GigabitEthernet0/23
description FILE3B (2-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/24
ip flow ingress
ip flow egress
interface GigabitEthernet0/25
description SQL1A (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/26
ip flow ingress
ip flow egress
interface GigabitEthernet0/27
description SAN-01 (L-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/28
ip flow ingress
ip flow egress
interface GigabitEthernet0/29
description SAN-01 (L-1)
ip flow ingress
ip flow egress
interface GigabitEthernet0/30
ip flow ingress
ip flow egress
interface GigabitEthernet0/31
description SAN-01 (R-2)
ip flow ingress
ip flow egress
interface GigabitEthernet0/32
ip flow ingress
ip flow egress
interface GigabitEthernet0/33
description SQL3 (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/34
ip flow ingress
ip flow egress
interface GigabitEthernet0/35
description TL-01 (Left)
ip flow ingress
ip flow egress
interface GigabitEthernet0/36
ip flow ingress
ip flow egress
interface GigabitEthernet0/37
description SQL1B (1-0)
ip flow ingress
ip flow egress
interface GigabitEthernet0/38
ip flow ingress
ip flow egress
interface GigabitEthernet0/39
ip flow ingress
ip flow egress
interface GigabitEthernet0/40
ip flow ingress
ip flow egress
interface GigabitEthernet0/41
ip flow ingress
ip flow egress
interface GigabitEthernet0/42
ip flow ingress
ip flow egress
interface GigabitEthernet0/43
ip flow ingress
ip flow egress
interface GigabitEthernet0/44
ip flow ingress
ip flow egress
interface GigabitEthernet0/45
ip flow ingress
ip flow egress
interface GigabitEthernet0/46
ip flow ingress
ip flow egress
interface GigabitEthernet0/47
ip flow ingress
ip flow egress
interface GigabitEthernet0/48
ip flow ingress
ip flow egress
interface GigabitEthernet1/1
description Uplink to SWI-11 (Gi1/1)
ip flow ingress
ip flow egress
channel-group 11 mode on
interface GigabitEthernet1/2
description Uplink to SWI-11 (Gi1/2)
ip flow ingress
ip flow egress
interface GigabitEthernet1/3
description Uplink to SWI-11 (Gi1/3)
ip flow ingress
ip flow egress
interface GigabitEthernet1/4
description Uplink to SWI-11 (Gi1/4)
ip flow ingress
ip flow egress
interface TenGigabitEthernet1/1
shutdown
interface TenGigabitEthernet1/2
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan665
no ip address
ip default-gateway 10.10.254.4
no ip http server
no ip http secure-server
ip flow-export source FastEthernet0
ip flow-export version 9
ip flow-export destination 10.10.254.30 2055
ip radius source-interface FastEthernet0
logging esm config
logging trap warnings
logging facility local1
logging source-interface FastEthernet0
logging 10.10.254.30
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server trap-source FastEthernet0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps ipmulticast
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps errdisable
snmp-server enable traps vlan-membership
snmp-server host 10.10.254.30 informs version 2c <removed>
radius server DC1
address ipv4 192.168.101.7 auth-port 1645 acct-port 1646
key 7 <removed>
radius server DC2
address ipv4 192.168.101.8 auth-port 1645 acct-port 1646
key 7 <removed>
banner exec ^C
You have logged in to a secure device. If you are not authorized to access this
device, log out immediately or risk possible criminal consequences.
^C
banner login ^C
You are logging in to a secure device. If you are not authorized to access this
^C
line con 0
password 7 <removed>
login authentication CONSOLE
line vty 0 4
session-timeout 60
exec-timeout 60 0
transport input ssh
transport output all
line vty 5 15
session-timeout 60
exec-timeout 60 0
transport input ssh
ntp source FastEthernet0
ntp server 192.168.101.7
ntp server 192.168.101.8
Switch11
Current configuration : 13223 bytes
! Last configuration change at 17:08:41 EDT Tue Mar 12 2013 by mike.griffin
! NVRAM config last updated at 17:08:42 EDT Tue Mar 12 2013 by mike.griffin
version 12.2
no service pad
no service dhcp
hostname SWI-11
boot-start-marker
boot-end-marker
no logging console
aaa new-model
server name DC1
server name DC2
system mtu routing 9000
ip domain-name .org
vtp mode off
vlan 14
name iSCSI
vlan 665
name Management
vlan 999
name UNUSED_PORTS
ip ssh version 2
interface Port-channel10
description Uplink to SWI-10
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip address 10.10.254.11 255.255.255.224
description NMS (Gb4)
ip flow ingress
ip flow egress
switchport port-security
ip flow ingress
ip flow egress
shutdown
description FILE1A (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE1A (2-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE1B (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE1B (2-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SQL2A (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SQL2B (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description MEDIA (Gb4)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE3A (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE3A (2-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE3B (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description FILE3B (2-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SQL1A (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SAN-01 (R-0)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SAN-01 (R-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SAN-01 (L-2)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SQL3
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description TL-01 (Right)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
description SQL1B (1-1)
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
ip flow ingress
ip flow egress
shutdown
description Uplink to SWI-10 (Gi1/1)
ip flow ingress
ip flow egress
channel-group 10 mode on
description Uplink to SWI-10 (Gi1/2)
ip flow ingress
ip flow egress
description Uplink to SWI-10 (Gi1/3)
ip flow ingress
ip flow egress
description Uplink to SWI-10 (Gi1/4)
ip flow ingress
ip flow egress
shutdown
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan665
no ip address
no ip http server
logging esm config
radius server HDC1
key 7 <removed>
radius server DC2
key 7 <removed>
banner exec ^C
^C
banner login ^C
^C
line con 0
line vty 0 4
session-timeout 60
exec-timeout 60 0
transport input ssh
line vty 5 15
session-timeout 60
exec-timeout 60 0
transport input ssh
end
You need to make the change on the port channel interface like this:
switchport trunk allowed vlan 14,665
switchport mode trunk
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
When interfaces are in a port channel, most of the configuration on the physical port is not actually used.
8 Replies 8
Reza Sharifi
According to your post, vlan 665 is for managment and 14 for iSCSI.  So, all the ports connected to iSCSI need to be in vlan 14.
Gregory Snipes
Level 4
Level 4
You need to convert the port channel that runs between these switches over to a trunk so that you can pass the additional VLAN.
Thanks for the reply. So If I understand this correctly I'll change the config to the following?
Switch 10
ip flow ingress
ip flow egress
spanning-tree portfast disable
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
Switch 11
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
Will I need to do anything with these lines?
ip flow ingress
ip flow egress
ip flow ingress
ip flow egress
After doing switchport mode trunk the following error is returned:
An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
put in "switchport trunk encap dot1q" before you hard set the port to trunk. Sorry, missed that bit.
Cool!  The iSCSI iniators are now connecting to the switchport on switch 11!!!  Thanks so much for the help!!!
Glad everything worked out.
