untagged trunk
David.Spencer
I was able to perform this on an Avaya switch, but we're moving to Cisco and I'm not sure how to perform this function on a CISCO. I'm aiming to do this on a C9200L
requirement:
device interface -vlan 32,40, with PVID 40. All untagged.
It requires both to be untagged, as the device has errors when it is tagged. It needs to be on both networks, as it needs to receive broadcast traffic from both, while broadcasting it's own traffic on the PVID. It must do this on a single network interface.
On avaya I could set "flexible tagging mode" and set multiple untagged vlans on the port.
I know this is a very non-standard configuration, but the equipment is over 20 years old and is very specific to it's requirements.
David.Spencer
It looks like what I require is switchport mode general, which in my previous hardware we just called "untag all".
the Catalyst 9000 series does not support switchport mode general, so it looks like I'll need to find a new hardware solution.
13 Replies 13
balaji.bandi
Cisco only allow 1 Native VLAN example  should work for you  as per the description, do test and let us know.
interface GigabitEthernet x/x
switchport trunk native vlan 40
switchport mode trunk
if you want more control :
switchport mode trunk allowed vlan 32,40
BB
Hi Balaji,
You might have missed the part in my post where all the vlans must be untagged, not just the pvid.
I've tested this as a regular trunk port as you've suggested without success.
Mark Elsen
 - Strange also in terms of standards, device should be vlan-aware if  it does not want to diffuse traffic on unneeded vlan's , opinions in these threads seem to align :
   https://community.cisco.com/t5/small-business-routers/rv320-why-can-a-port-only-have-one-untagged-and-multiple-tagged/td-p/2690574
  https://community.cisco.com/t5/switching/can-i-configure-multiple-native-vlans-on-a-single-trunk-link-on/td-p/4142856
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The device is for DECNET and VAX communication, so it's very particular. It's not VLAN aware, and needs to communicate to both.
The DECNET and VAX systems need to be on separate VLAN's as they are very sensitive to noise.
I can get this to work on nortel/baystack/avaya/extreme switches as they allow you to have multiple access vlans on a single port ( or fully untagged trunk). I'm hoping that Cisco can provide some sort of similar funcionality.
 - Must use some mac address prefix knowledge to know to whom to talk too. Must defend cisco here, as other reply indicated , that is very outdated ,modern hardware such as hypervisors , fileservers , etc are all vlan-aware in these days.  I used to work on DECnet and vms too , more then 30-years ago , where are the days (smile).
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I agree, all modern systems are generally vlan aware, however these aren't modern. They were installed in the 80s (VAX) and early 90s (DEC), and cannot be replaced yet.
I wish our production used hardware built in this century, but it is not. All I know is that if I change the interfaces to standard Trunk format, or add any form of tagging, the systems fail to communicate until changed back.
Joseph W. Doherty
Interesting that other vendor(s) allow this, because consider where should ingress traffic on such a port be directed?  I.e. you effectively changed multiple VLANs into one VLAN.
Two ways I see it might be done on a Cisco device.  On a L2 switch, you might have one all three VLANs directed to access ports, one for each VLAN.  Then you might also have additional access ports for one of the VLANs.  Those ports would be connected to access ports other than the one VLAN.
E.g.
access port VLAN 10 (this port would should all the VLANs traffic)
access port VLAN 20 connected to a VLAN 10 access port
access port VLAN 30 connected to a VLAN 10 access port
The other way, on a L3 switch, would be to have your multiple VLANs routed to a routed port.
For the other vendors, ingress traffic is defaulted to the PVID (native vlan). The end result is that the device is listening to all the vlans on the port, and it's outbound traffic is on the PVID, without the device seeing the tags.
None of the protocols it uses is directed traffic, all the devices on these subents only communicate with a broadcast type traffic, either in form of modbus, decnet, SAF, or whatever the VAX is using.
David.Spencer
Hello
On the catalyst 9000 have you tried making the port an trunk to allow all vlans with fictitious native vlan of your choosing and on the Avaya switch set the pvid to the same fictitious untagged vlan
9000
switchport trunk native vlan 999
switchport mode trunk allowed vlan 100,110,120
Avaya
x/x
switchport general pvid 999
switchport general allowed vlan add 100,110,120 tagged
or
9000
switchport mode access
switchport access vlan 1
Avaya
x/x
Kind Regards
Paul
Hi Paul,
Please read the full post. I'm not trying to make a trunk between an avaya and cisco switch. I'm connecting an end device that needs multiple untagged vlans (switchport mode general) on the cisco c9000, similarly to how i'm able to on avaya and dell switches.
Hello
So the below would in theory allow all untagged traffic
9000
Avaya
x/x
Kind Regards
Paul
How would setting "switchport mode access" and "switchport access vlan 1" allow multiple untagged vlans on that port? That should only support traffic from vlan1.
