Upgrade C6509 Chassis to C6509-E Gotchas?
monty4952
Hello
I will be replacing our current single chassis (WS-C6509) with the (WS-C6509-E) chassis.  What I want to do is just take our line cards from our current chassis below and place them in our new chassis.  Considering we are moving the Supervisors also, do I need to make sure of anything as far as configuration?  The swap just seems to straight forward but maybe I'm looking too into this.  I've backed up the IOS, configs that include the ACLS since we use it as our firewall.  After I moved over the line cards and powered up  I was only going to connect our Supervisors which connect to our ISP to verify route connectivity then for the most part everything else are trunks going to our switches.
I'm curious if their are any gotchas or things I should be prepared for whether it be hardware or configs.  Any tips would be greatly appreciated.
Mod Ports Card Type                              Model
  2   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  3   24  24 port 100FX Multi mode               WS-X6324-100FX-MM
  5    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
Mod  Sub-Module                  Model                Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC         4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B         2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720            3.1    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B         2.5    Ok
  6  MSFC3 Daughterboard         WS-SUP720            3.5    Ok
  8  Centralized Forwarding Card WS-F6700-CFC         4.1    Ok
  9  Centralized Forwarding Card WS-F6700-CFC         4.0    Ok
system power redundancy mode = redundant
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power used =      1404.48 Watts (33.44 Amps @ 42V)
system power available = 1366.68 Watts (32.54 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  OK     OK     on
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
2    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
3    WS-X6324-100FX-MM    63.84  1.52    63.84  1.52  on    on
5    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
6    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
8    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
9    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   3780.00 Watts (90.00 Amps @ 42V)
system auxiliary connector power limit = 0 Watt
system primary power used =              1404.48 Watts (33.44 Amps @ 42V)
system auxiliary power used =            0 Watt
Jose Solano
Level 4
Level 4
As far as I can see all the linecards including the superviors are fully compatible with the WS-C6509-E chassis, same as with the WS-6509 the sup engines can only occupy the slots 5-6 in the chassis and the line cards any other slot. As per the IOS if you will be using the same you had before you should not not face any issues.
Hope this helps.
Jose Solano
Level 4
Level 4
Hope this helps.
