used install all kickstart command failed on:
boot variable "system" FAIL. Return code 0x4045001E (mismatch between actual image type and boot variable).
Version compatibility check failed. Return code 0x40930011 (Image verification failed)
Did not think this was a memory problem but unable to locate documentation on above.
Any help is appreciated
v/r
dir bootflash:
Usage for bootflash://sup-local
261545984 used
621805568 free
883351552 total
