Upgrade Nexus C3548P-10GX in vPC
thuy.hoang
Dear Buddy,
I have 2 x Nexus C3548P-10GX in vPC. I would to upgrade the current version 9.2.3 to newest version 9.3.4. Could anyone have experience with upgrade the Nexus in vPC? Appreciated if anyone can advise me the procedure.
Thank you.
The current boot version:
Software
BIOS: version 5.0.0
NXOS: version 9.2(3)
BIOS compile time: 05/22/2018
NXOS image file is: bootflash:///nxos.9.2.3.bin
NXOS compile time: 2/17/2019 5:00:00 [02/17/2019 22:07:27]
CoreSwitch_1# show boot
Current Boot Variables:
sup-1
NXOS variable = bootflash:/nxos.9.2.3.bin
Boot POAP Disabled
Boot Variables on next reload:
sup-1
Boot POAP Disabled
Sergiu.Daniluk
Hi @thuy.hoang
Before doing the upgrade, always start with reading the release notes for the target image and upgrade guides:
Few notes you should be aware of:
+ start the upgrade with the vPC operational secondary
+ since you have a Nexus 3500 you will most likely need to use the compact option while copying the file to bootflash:
switch# copy scp://user@server-ip/image-path/ bootflash: compact vrf management
+ Since in this 9.x version there is no kickstart image, the command for upgrade is:
switch# install all nxos bootflash:nxos.9.3.1.bin
+ read the release notes and upgrade guides. yes, I repeat myself :-) trust me, it will save you from unexpected problems.
Stay safe,
Sergiu
7 Replies 7
balaji.bandi
read the release notes  and understand the caveats, check is this effect your environment :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/release/notes/934/934_3000_3500_3600_rn.html
1) Save configuration before starting.
2) Check there is enough space on devices
3) Copy over firmware to the bootflash, both kickstart firmware and system files.
copy to disk copy ftp://x.x.x.x/x.x.bin bootflash:
4) install all kickstart x.x.bin system yy.1.bin
5) Once the secondary responds to pings again, logon and check that the secondary 3K has come back up with the right firmware
Checking that vPC (protocol used for the network resilience), is up correctly by doing a show vPC, before upgrading the primary.
show vPC
6) Repeat process for Primary device
BB
Sergiu.Daniluk
Hi @thuy.hoang
Stay safe,
Sergiu
@Sergiu.Daniluk  - thanks for heads up i missed as normal upgrade.. good stuff...
BB
No worries my friend! Take care and stay safe!
Sergiu
Hi buddy,
I am very appreciated with your warm reply. I will plan to do upgrade in next weekend, will let you know the status.
Thank you so much.
Let us know how it went!
Cheers,
Segiu
Hi @Sergiu.Daniluk ,
I have upgraded the N3K successfully.
Thank you so much for your warm support.
