Upgrading C9200 with .bin INSTALL mode, space questions.
danielrattee
XXXXSW-030#show install summary
[ Switch 1 2 ] Installed Package(s) Information:
State (St): I - Inactive, U - Activated & Uncommitted,
C - Activated & Committed, D - Deactivated & Uncommitted
Type St Filename/Version
IMG C 16.12.08.0.7211
Auto abort timer: inactive
133 466436833 Nov 24 2022 09:52:32.0000000000 +00:00 cat9k_lite_iosxe.16.12.08.SPA.bin
134 470661439 Sep 22 2023 12:18:16.0000000000 +00:00 cat9k_lite_iosxe.17.09.04.SPA.bin
135 392905752 Nov 24 2022 09:58:20.0000000000 +00:00 cat9k_lite-rpbase.16.12.08.SPA.pkg
136 1456 Jul 06 2023 02:27:08.0000000000 +00:00 stby-vlan.dat
137 40586949 Nov 24 2022 09:59:15.0000000000 +00:00 cat9k_lite-rpboot.16.12.08.SPA.pkg
138 387843092 Nov 15 2020 16:10:02.0000000000 +00:00 cat9k_lite-rpbase.16.12.04.SPA.pkg
139 40637261 Nov 15 2020 16:10:47.0000000000 +00:00 cat9k_lite-rpboot.16.12.04.SPA.pkg
140 4576276 Nov 15 2020 16:10:02.0000000000 +00:00 cat9k_lite-srdriver.16.12.04.SPA.pkg
141 10171408 Nov 15 2020 16:10:02.0000000000 +00:00 cat9k_lite-webui.16.12.04.SPA.pkg
142 23053336 Nov 24 2022 09:58:20.0000000000 +00:00 cat9k_lite-srdriver.16.12.08.SPA.pkg
143 10195988 Nov 24 2022 09:58:20.0000000000 +00:00 cat9k_lite-webui.16.12.08.SPA.pkg
144 4885 Nov 24 2022 09:59:15.0000000000 +00:00 cat9k_lite_iosxe.16.12.08.SPA.conf
0 bytes available (1862979584 bytes used)
Following the upgrade guide I am able to put cat9k_lite_iosxe.17.09.04.SPA.bin onto the flash of both switches, however, when I go to do the install add command it fails. I know why it fails, because there isn't any space available to expand the .bin into its applicable .pkg files.
My question is: can I remove cat9k_lite_iosxe.16.12.08.SPA.bin from flash without affecting the 16.12.08 .pkgs so that I can install the 17 .bin and then proceed with the upgrade? After that completes I would run install remove inactive to remove the old 13 .pkgs
 more flash:packages.conf returns # pkginfo: Build: 16.12.08 currently.
My thought process is that I can delete cat9k_lite_iosxe.16.12.08.SPA.bin because its essentially a zip file that has already been unpacked to its. .pkgs, but I want to be absolutely sure before I go deleting things from a production device.
17 Replies 17
Understood.
I'll run it the next time I have a production downtime window (should be this weekend), and I'll update this posts with the results.
Thank you all.
It went a lot more smoother than I was thinking it was going to go. Maybe I shouldn't be so pessimistic.
install remove inactive did work and I was able to active the newer version
sure that works, we have many upgrade that is way to clean the files and upgrade path.
BB
