URL Filtering WITHOUT Websense?
brider
Hi folks. I am new to Cisco products and there are a few things I am
trying ot configure. I am running a 2821 Router with IOS v 12.4(10a).
I am trying to configure the URL filtering portion of the firewall ACL.
I have configured to deny one site, then I enable the filter and it
shuts down all internet sites. When I disable the URL filtering,
everything works fine again. This looks pretty cut and dry but
apparently it is not. I was also reading that I needed a websense
server to use this feature? Is that correct? Thanks.
23 Replies 23
Collin Clark
Yes a proxy server is required.
Okay thanks. That is what I thought.
stephen.stack
Level 4
Level 4
hmmmm, i had a big long chorus written out for you explaining that local URL filtering would work and how to implement it, but i decided to just test it on my own 831, IOS12.3(8)T8 when i discovered that i have exactly the same issue as you. I have done this before for customers. Maybe it is a bug.
Might try it with an older IOS later, just to test it.
If anyone else has any ideas, i'd like to know too.
Cheers
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Sorry I read it too fast, I thought it was a PIX. I never tried it with IOS.
juan_m_12
Hi i have the same situation with a 2821 router with IOS Version 12.4(7c), i cant be donde without a websense server only to block specific url like www.hotmail.com ??
thanks
Juan Garcia
You can use the IOS f/w URL filtering without using the Websense server.I would like to check the IOS configuration done on the router.
Please paste the router configuration.
HTH,
-amit singh
Hi folks. I didn't know this thread was still active but I did find the answer to my solution through a friend by using the urlfilter exclusive domain....etc. command. Thanks to everyoen for their help.
hello, can you post your solution to filter URLs please?
---- actually we have only the basics configured by SDM and some by CLI
ip name-server <>
ip name-server <>
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip ips sdf location flash://128MB.sdf autosave
ip ips notify SDEE
ip ips name sdm_ips_rule
interface GigabitEthernet0/0
ip address 10.1.1.5 255.255.252.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip ips sdm_ips_rule in
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0:1
ip address <>
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect SDM_LOW out
ip ips sdm_ips_rule out
ip route-cache flow
load-interval 30
no fair-queue
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:1
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 deny any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 remark Auto generated by SDM for NTP (123) 131.107.1.10
access-list 100 permit udp host 131.107.1.10 eq ntp host 10.1.1.5 eq ntp
access-list 100 remark Auto generated by SDM for NTP (123) 192.43.244.18
access-list 100 permit udp host 192.43.244.18 eq ntp host 10.1.1.5 eq ntp
access-list 100 deny ip <> any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host <>
access-list 101 permit tcp any host <>
access-list 101 permit udp host <> eq domain host <>
access-list 101 remark Auto generated by SDM for NTP (123) 131.107.1.10
access-list 101 permit udp host 131.107.1.10 eq ntp host <> eq ntp
access-list 101 remark Auto generated by SDM for NTP (123) 192.43.244.18
access-list 101 permit udp host 192.43.244.18 eq ntp host <> eq ntp
access-list 101 deny ip 10.1.0.0 0.0.3.255 any
access-list 101 permit icmp any host <> echo-reply
access-list 101 permit icmp any host <> time-exceeded
access-list 101 permit icmp any host <> unreachable
access-list 101 permit tcp any host <> eq 443
access-list 101 permit tcp any host <> eq 22
access-list 101 permit tcp any host <> eq cmd
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
no cdp run
ntp clock-period 17180301
ntp update-calendar
ntp server 192.43.244.18 prefer
ntp server 131.107.1.10
end
i try the command
ip urlfilter exclusive-domain deny www.hotmail.com
(that was added by SDM using "url filter") but SDM blocked all pages.
thanks beforehand
Juan Manuel Garcia
i finally found out,
first i need to activate the command:
ip urlfilter allow-mode on
to inspect the url even without a websense server
and then the command:
ip urlfilter source-interface eth0/0
to apply the filtering i guess
and finally the commands:
ip urlfilter exclusive-domain deny .danger.com
the dot in the first indicates any webpage in that domain, and you just need to specify the deny?s than the permits because the allow-mode on command permit everything but the specified urls
thanks everybody for the posts
anyone know if theres a performance issue filtering url this way?
Juan Manuel Garcia Reyes
Hi Brider,
this is working configuration which i use in myu organization to block the google chat & meebo.com site. i am using this for the past 4 monthz without any problme on my Cisco 1751.
ip inspect alert-off
ip inspect name URL_FILTER http java-list 2 urlfilter
ip urlfilter cache 5
ip urlfilter exclusive-domain deny chatenabled.mail.google.com
ip urlfilter exclusive-domain deny .meebo.com
ip audit notify log
ip audit po max-events 100
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
ip inspect URL_FILTER in
speed auto
access-list 2 permit any
the above config will block the sites what i hav listed & rest all are allowed, bcoz "ip urlfilter allow-mode on" command is mentioned, if this is not mentioned, then it blocks the entire internet traffic. so make sure that ur issuing this command.
i hope this helps.
rate this post if satisfied.
Can you do this on an ASA 5505??
YES URL filtering can be configured even on ASA also.
How?
