Usage of Radius server groupname on Cisco Switches
CSCO10675262_2
I am trying to understand the usage of a radius server command I came upon:
radius server groupname
ip address ipv4 1.1.1.1.  auth-port 1812 acct-port 1813
key key1
automate-tester username user1
I was wondering if it may be an enhancement/replacement of the usual 'radius-server host...' command?
Thanks.
Bilal Nawaz
Hello, I'd like to think of this as a much tidier way of configuring radius groups or tacacs groups. Although some people find it cumbersome.
You could specify the individual host, however I think this CLI will be depreciated soon. If you have more than one, it makes sense to put them in a group. Another reason would probably be for added resiliency.
What if one of them fails? then the next one in the group is attempted.
Also the later versions of IOS permit the use of IPv6 also, you are correct - it will be a replacement so syntax has changed in the command you mentioned when you use the old commands you may see:
This cli will be deprecated soon. Use new server cli
Reason being, Cisco introduced the commands in the later versions of IOS to replace the host commands:
radius server MYRADIUS
ip address ipv4 x.x.x.x
key xxxxxx
ip address ipv4 y.y.y.y
key yyyyyy
and also same for tacacs
tacacs server MYACS
key xxxxxx
key yyyyyy
instead of
radius server host x.x.x.x  key xxxxxxx
Hope this helps.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Richard Atkin
Level 4
Level 4
Groups are used in addition to the radius-host stuff you mention. Groups allow you to be more specific about which particular servers, or groups of servers, are used for what particular switch function, ie, TACACS, RADIUS Auth, RADIUS Acct, Login, etc. It's quite a commonly used feature.
Richard is right, on modern Cisco switch or router devices you could use somthing like this, by using different groups
username {MyEmergencyUsername} secret {MyEmergencyPassword}
enable {MyEmergencyEnablePassword}
aaa new-model
! This group will be used for console login
aaa group server radius {MyRadiusGroupForConsoleLogin}
server-private 1.1.1.1 auth-port 1812 acct-port 1813 key {MyRadiusKey}
server-private 2.2.2.2 auth-port 1812 acct-port 1813 key {MyRadiusKey}
ip radius source-interface {MySourceInterface}
exit
! This group will be used for vty login
aaa group server radius {MyRadiusGroupForVtyLogin}
server-private 3.3.3.3 auth-port 1812 acct-port 1813 key {MyRadiusKey}
server-private 4.4.4.4 auth-port 1812 acct-port 1813 key {MyRadiusKey}
exit
! AAA configuration for the different groups
aaa authentication login CONSOLE group {MyRadiusGroupForConsoleLogin} local-case
aaa authentication login VTY group {MyRadiusGroupForVtyLogin} local-case
aaa authentication enable default group {MyRadiusGroupForConsoleLogin} {MyRadiusGroupForVtyLogin} enable
line con 0
login authentication CONSOLE
exit
line vty 0 15
login authentication VTY
exit
asdad
Bilal Nawaz
key xxxxxx
key yyyyyy
tacacs server MYACS
key xxxxxx
key yyyyyy
instead of
Hope this helps.
Hi All,
Appreicate for the wonderful information. I was previously configuring 'aaa group server radius' for dot1x as pointed out by
asdad  when I came across the 'radius server group' reference which confused me as I was unable to find any documetation for it.
Thank you for the great information
