Using VACLs to replace SPAN
jdevoll
Level 3
Level 3
Due to the limitations in the number of SPAN sessions across all switching platforms, I am planning on using a VACL w/ the capture option to mimic a SPAN session. Below is a copy of the config that I believe will safely achieve this:
ip access-list extended span_acl
permit ip host 192.168.1.1 any
permit any ip host 192.168.1.1
ip access-list permit_all
permit ip any any
vlan access-map test
match ip address span_acl
action forward capture
match ip address permit_all
action forward
vlan filter test vlan-list 101,102
int G1/1
switchport capture allowed vlan all
switchport capture
Two questions:
1. Is this necessary or is it already implied (the config guide wasn't 100% clear)
action forward
2. In order to capture bi-directional traffic, is it necessary to configure mirror ACE entries as I have done, or is this also implied?
Thanks much! Any additional constructive input will be appreciated.
Prashanth Krishnappa
Yes to both your questions. It is not implied otherwise. But for 1, the syntax would be something like this
vlan access-map test 10
vlan access-map test 20
action forward
action forward
Sweet! Thank you for your input.
