VDC question
XIE YAO
Level 5
Level 5
Hi team,
New to NXOS, not sure if this is the right place to post.
Just want to know if I run a show-tech in one VDC, will it include information for other VDC as well?
Thanks.
2 Accepted Solutions
The admin vdc which is usually vdc id 1 anyway.
Default and admin VDC cannot coexist at the same time. VDC 1 can either configure as default or Admin.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
InayathUlla Sharieff
To get this info:-
Show tech vdc-all -( run this from default vdc and it will captured all vdc info)
Inayath
Bilal Nawaz
I can't remember since its been a while when i ran show tech on a N7K, but from what I recall, if you do show tech from the default VDC, it should capture for all other vdc's. Not sure if there was an option to choose a vdc by its name after the command like "show tech vdc" I dont think it was the case.
when you say default vdc, are you referring to the vdc id 1? or admin vdc?
To get this info:-
Inayath
