09-29-2008 02:07 AM - edited 03-06-2019 01:39 AM
Is it possible to configure both Catalyst and Linksys switch to work together for VLAN and Etherchannel ? If yes, can you give me the resources which I can refer to ?
Thanks very much.
Daniel Alex
09-29-2008 02:15 AM
Daniel,
Which model of Cisco & Linksys are you refering to?
09-29-2008 05:07 PM
Hi Andrew,
Cisco CAT4507R (WS-C4507R) and Linksys 48-port 10/100/1000 Switch + 4 shared mini-GBIC Ports (SRW2048P)
Thanks & regards
Daniel
09-29-2008 05:23 PM
Yes it should , looking at the stat sheet for the linksys says it supoorts lacp so you should be able to etherchannel ports together as the 4506 supports lacp also .
