VLAN information not propagate
ahpark78
Hi guys,
I have problem propagating the VLAN information although the VTP domain and password is the same for both switches..
I can propogate the VLAN no but not the description or the name of the VLAN meaning the Configuration changes didn't reflect on the other switch.
SWITCH A - VTP SERVER
CONFIGURATION is 17
Switch B - VTP CLient
Configuration is 16
NEed your assistance..
thanks!
ken
22 Replies 22
Hi Ken,
Try deleting the VLAN database file from the client switch and reload it if you can
delete flash:vlan.dat
Then configure the same VTP domain name and password on the switch and see if the VLANS are replicating
HTH, rate if it does
Narayan
check your trunks first..issue a show int. & post capture here as well as your current vtp status. thx
4506 sho vtp:
VTP Version : 2
Configuration Revision : 60
Maximum VLANs supported locally : 1005
Number of existing VLANs : 20
VTP Operating Mode : Server
VTP Domain Name : ******
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x8A 0xB3 0xCE 0x53 0xB2 0x24 0x06 0x32
Configuration last modified by 10.201.127.1 at 8-23-06 06:49:25
Local updater ID is 10.201.127.1 on interface Vl1 (lowest numbered VLAN interface found)
3750 sho vtp :
VTP Version : 2
Configuration Revision : 47
Number of existing VLANs : 19
MD5 digest : 0x14 0x15 0xB2 0xF6 0x38 0x3C 0x23 0x9A
Configuration last modified by 10.201.127.7 at 3-1-93 05:26:12
Local updater ID is 10.201.127.22 on interface Vl1 (lowest numbered VLAN interface found)
int mode all trunk,encapsulation dot1q
thanks
A couple things...
-Are you trunk ports actually trunking? (CatOS = "show trunk" or IOS = "show interfaces card-type {mod/port} trunk") post printout here.
- Check vtp domain name (case-sensitive)
-set one vtp to client mode & one to server
-Do not enable VTP V2 unless every switch in the VTP domain supports V2.
-Reset your config revision by renaming the vtp domain name then back to original...recycle switches.
hi micharlcOn
I chack all these things,no error on these
I find these two switch has different MD5 digest,i think this is the main reason ,how can I correct this ?
thanks
The vtp password MUST be the same on all switches & you must configure the password on all switches in the VTP domain. You can change this in the global config:
Router(config)#vtp password "123456789"
all switch is same ,they have't vtp password.is this correct ?
smothuku
Level 7
Level 7
Hi ,
can you enable cdp on both switches and check what's happening between two switches.
