VLAN IP removal
paul dungey
Good afternoon,
I have an other niggling question, My switch Vlan looks all clear but when i run the command show running-config, to check that all IP information has been erased from the switch the Vlan is showing an IP address and i need help removing this, see content rom switch below.
switch#
switch#en
switch#show ru
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 192.6.8.1 255.255.255.0
no ip directed-broadcast
no ip route-cache
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4,
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8,
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12,
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16,
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20,
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24,
                                                Gi0/1, Gi0/2
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      0      -        -    -        0      0
1003 tr    101003     1500  -      0      -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
switch#
Paul
just login in switch...
switch#config t
Switch(Config)#int vlan 1
SWitch(Config-vlan)#no ip address
thats all you need to remove the ip.
Sandeep
5 Replies 5
Sandeep Choudhary
Hi Paul.
use this
Switch#config t
Switch(Config-vlan)#Interface vlan x
Switch(Config-vlan)#no ip address
Please rate if it helps.
HI Sandeep
How do i access
Switch(Config-vlan) from privlage mode???
Paul
switch#config t
Sandeep
Hi Paul,
you should probably to erase the file on the flash memory with all the info about the vlan. Often is vlan.dat
default interface vlan 1
could be something else to try.
Alessio
Sandeep,
Thank you for your support, the commands worked and i no longer have the Interface VLAN1 showing any IP address.
regards,
Paul
