VLAN not able reach after applied ISR device
Hanif Saharudin
Dear Experts,
We have installed Cisco ISR(ISR_1 and ISR_2) and Cisco FW(FW_1 & FW_2) as per photo below.
I already perform PERMITALL to each FW. So no blocking issue in FW.
We perform test FW_1 to FW_2 (using cross cable)without ISR, all the VLAN able to ping each other.
My question why we not able to reach at VLAN 514,515 and 516 to VLAN 114, 115, 116 after implementing ISR devices.
VLAN 514: 10.5.14.0/24 10.5.14.254                         VLAN 114: 10.51.14.0/24 10.51.14.254
VLAN 515: 10.5.15.0/24 10.5.15.254                         VLAN 115: 10.51.15.0/24 10.51.15.254
VLAN 516: 10.5.16.0/24 10.5.16.254                         VLAN 116: 10.51.16.0/24 10.51.16.254
Is it that issue on FW config or ISR config? Really need help on solving this issue.
Thanks.
Hanif
5 Replies 5
D_Lebedev
Level 3
Level 3
To solve your issue you have configure trunk port on each interface:
1) ISR1---ISR2
2)ISR1--FW1
3) ISR2--FW2
As in your scenario,intervlan routing on fws needs trunk ports outside of firewall.
Hope it helps.
You do not need to configure trunks between all the devices in this scenario.
Providing the firewalls allow the traffic and the routing is setup correctly it should work fine.
Jon
Hi John ,
Updated on this issue, firewall (10.5.5.250)connected to  L3 Switch with Access port while ISR connected to L3 switch with Trunk port. Attached is the show run for these 3 devices. ISR using
EtherSwitch Service Module (ES)  Int GI 1/0 to connect with L3 Switch.
I don't see how this post relates to the original problem.
Did you see my first post about the missing routes on ISR_1 ?
Jon
Jon Marshall
The routing table on ISR_1 does not have routes for the 51x vlans.
Is the interface between FW_1 and ISR_1 up on the the ISR ?
Jon
