VLAN problem with SONET/SDH Equipment
tookenyip12
Hi all,
Recently I did a test with 2x 2960 and 2x SDH equipment from Haliplex. According to the vendor they're on Layer 1 only.
As per the diagram, we have a Catalyst 2960 on each end. Both Gi0/1 on the 2 switches are configured as trunk. So I have 2 laptop plugged in on the switches and we can ping each other. When I create a 2nd VLAN on both the switches, I get error message "vlan ID mismatch" and some peer inconsistency error. I show spanning-tree and I see the Gi0/1 status is BKN. I believe it meant broken.
Have anyone encounter this kind of issue before?
spremkumar
Level 9
Level 9
can you post the config of both the switches and also the show logs ouput with the error messages you are getting over there.
regds
I think they have mapped only a single vlan in VCG, this could be the reason for not forwarding all the vlans.
regards
Shivlu Jain
http://www.mplsvpn.info
Hi what's a VCG? Anyway, I will get the error logs from the customer site tomorrow or the day after.
