vlan routing issue
dave dave
Level 3
Level 3
hi! I tried to configure a router  on the stick kind of setup. Refer to the config below. I set my pc nic with the correspond vlan IP and gw, i noticed that i can only ping its own vlan gw but not other vlan's gw. I think this shd be a straightforward setup, but somehow it doesn't work in this case. Anything that i missed out? Thanks.
SW Config
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 48
name SvrMgt
vlan 49
name Data
vlan 50
name Voice
vlan 51
interface GigabitEthernet0/1
switchport access vlan 49
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/2
switchport access vlan 51
interface GigabitEthernet0/3
switchport access vlan 48
interface GigabitEthernet0/47
description Connect to router
switchport trunk native vlan 48
switchport mode trunk
interface Vlan1
no ip address
interface Vlan48
ip address 10.200.1.2 255.255.255.192
ip default-gateway 10.200.1.1
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Router Config
version 12.4
hostname abc
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.10
encapsulation dot1Q 48 native
ip address 10.200.1.1 255.255.255.192
no snmp trap link-status
interface FastEthernet0.20
encapsulation dot1Q 49
ip address 10.200.1.65 255.255.255.192
interface FastEthernet0.30
encapsulation dot1Q 50
ip address 10.200.1.129 255.255.255.192
interface FastEthernet0.40
encapsulation dot1Q 51
ip address 10.200.1.193 255.255.255.192
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
no ip address
shutdown
router ospf 8
log-adjacency-changes
network 10.200.1.0 0.0.1.255 area 0
network 10.280.14.222 0.0.0.0 area 0
11 Replies 11
cadet alain
Have you specified ip address of router subinterface for that vlan as default gateway ?
Regards.
Alain.
hi! Yes, i did. I tried for all the avail vlans. Everytime i changed, i can only ping my own vlan's GW.
raschlosser
Visitor
Hi Dave Dave,
can you please post the routing table from your router?
Ralf
JohnTylerPearce
Level 11
Level 11
It looks like your setup is as follows.
Router -----> Switch -----> Hosts
You don't really need the vlan interface on the switch since you already have a L3 interface on your router.
You don't really need the gateway as well since you can just use L2 untill you need to hit the router.
Those networks should be directly connected off of that router so they will already have a directly connected
route so I don't think you will really need the OSPF configuration in there unless you have something else going on.
Basically your hosts will be communication via L2 until they need to talk to someone out of their broadcast
domain (L2 domain if you will). That L2 frame will go towards it's default gateway which will be whatever the
interface is on your router. (Vlan 48 - 10.200.1.1) (Vlan 49 - 10.200.1.65) (Vlan 50 - 10.200.1.129) (Vlan 51 - 10.200.1.193)
    The switch has an address to manage it , the default gateway on the switch is there because ip routing is turned off on the switch so you use a default gateway statement so it can be managed from any subnet.  .   Do you have your fw turned off on your pc ?    Verify the gateway on your pc is correct before pinging with the ipconfig /all  from the dos prompt. .
hi! thanks all for the reply. i think the sw and router config is correct. The issue is with my laptop wireless connection, once i turned on my wireless connection (which connect to the live env) i can't seems to ping any gateway (within the test env) by itself? any idea why is that so?
Another question is that, I've the following config. I can ping any gateway within my test env without any issue if my laptop is configured as vlan 49's IP statically. If i configure my laptop with vlan50 IPs i can't seems to ping any gateway. Is it because it's a must to configure dhcp in the voice vlan? or the switch will detect that the pc is not a phone/voice equipment, thus it doesn't allow it to go anyway? Thanks.
switchport voice vlan 50
no mdix auto
hi,
if you configure pc in vlan 50 subnet frames coming from it are untagged so considered to be part of vlan 49.
Because your config is telling the switch to advertise via cdp the vlan id the phone must use to tag its frames.
For your wireless, is it configured in same subnet as the ethernet?
Regards.
Alain.
Hi sorry, I don't quite understand the first paragraph. I think basically you meant it's norm that I can't reach any gw if a pc configured with avoice vlan ip is connected to port configured with voice + data vlan? No the wireless networks is different segment from my test env.
Yes because this access-port is in fact a mini-trunk port and as you pc doesn't tag frames they are considered belonging to vlan 49 no vlan 50.
Regards.
Alain.
Fabio Francisco
Level 5
Level 5
Hey mate,
I think your problem is the wildcard set up in OSPF
Try this:
router ospf 8
network 10.200.1.0 0.0.0.255 area 0
Cheers,
Fabio
The configs look good to me too
I dont see anything wrong with the OSPF as it is.
! ## This will match IP addresses in the range 10.200.0.1 - 10.200.1.254 all your addresses are in this range
But anyway the connected interfaces are AD = 1 where as OSPF would AD=110. Connected routes would be used.
If you use the switch console to ping istead of a PC
Switch/Console will use 10.200.1.2 with its d/gway 10.200.1.1
Ping 10.200.1.2  result = ? - (Just to make sure IP stack is working)
Ping 10.200.1.1  result = ?
Ping 10.200.1.65  result = ?
Ping 10.200.1.129  result = ?
Ping 10.200.1.193  result = ?
If the results are good then the issue mut be with your test PC, perhaps internal firewall etc.
Alex
Regards, Alex. Please rate useful posts.
