Vlans talking to each other without subinterfaces set
aconticisco
Level 2
Level 2
I have set up a couple of vlans on a cisco 1721 router 4esw card using the vlan database and assigning an ip address of 192.168.1.x and 192.168.2.x for each vlan interface.
Strangely enough connected computers can talk to the other vlan and I have not set any subinterfaces on the etherner0 (layer 3) and not even connected a cable.
Is there any reason why this should happen since they should not talk to eachother being on seperate vlans.
Doing a tracert shows that first the vlan ip address is hit and then straight to the target pc in the other vlan
2 Accepted Solutions
Giuseppe Larosa
Hello Aconticisco,
the 4ESW module supports multilayer switching like a standalone C3560- C3750, if you have defined the vlans in the database and you have also configured the associated SVIs ( layer3 interfaces Vlan X and Vlan Y) with IP addresses in the involved IP subnets 192.168.1.0/24 and 192.168.2.0/24, then inter vlan routing is provided by the module as your traceroute test confirms.
You don't need to provide L3 services using the router interface as the module is multilayer capable,
Hope to help
Giuseppe
I thin you can put an ACL to filter traffic and apply it on each SVI.
Giuseppe Larosa
Hello Aconticisco,
Hope to help
Giuseppe
thank you for the information. I would like to avoid this situation and have the vlans completely isolated.
How can I achieve such result where example vlan 2 is unable to communicate with devices on vlan 3 using the 4ESW
Thank You all now it is all clear and working
