12-13-2019 12:46 PM
I noticed we cannot configure the voice vlan command on the N9K. Our model is C93108TC-EX. Sw version is 7.0(3)I4(3)
Some other discussions suggested trunking both data and voice vlans? Has anyone tried it ?
Can we try this configuration instead ?
int e/1
switchport
switchport mode trunk
switchport trunk allowed vlan <data-vlan>
switchport trunk native vlan <voice-vlan>
12-13-2019 01:35 PM
you need to set the port to trunk mode and allow both the data and the voice Vlan, as in the example below:
Interface e1
switchport
switchport trunk allowed vlan 100, 200
12-13-2019 01:42 PM
Thansk for the response.
Will the VoIP phone be able to untag the right vlan and assign it to desktop port ? Have you tried this configuration with a desktop attached to a phone ?
12-13-2019 01:37 PM
it does not support - nexus more of Datacenter switches for Server environment - you looking Enterprise or Campus Lan feature on DC switches.
here is reference :
https://community.cisco.com/t5/switching/nexus-9000-voip-command/td-p/2765567
12-13-2019 01:45 PM
Thanks for the response. Its a one-off. Looking for a couple of VoIP phone on the DC floor. Not looking for system wide LAN solution.
Has this been tested ?
Will the VoIP phone be able to untag the right vlan and assign to the desktop port on the phone ?
03-30-2023 10:04 AM
Yes if you go the phones admin settings you can manually set the admin (phone) and pc vlan from the phones UI.
