Web GUI and CLI unavailable/not working
Ikon1
I have an cisco 300sf-24pp network switch and I am unable to access the web GUI or the CLI.
The switch is working with 100 up and 100 down.
Iv'e tried factory reseting it but same issue
balaji.bandi
Turn off the device wait for 10min, and do the factory reset :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350-series-managed-switches/smb985-how-to-manually-reboot-or-reset-a-switch.html
not sure if we understand this, what is 100 up and 100 down mean?
BB
12 Replies 12
Mark Elsen
         - What address did you try (e.g.) ? What happens when you try to use  the  GUI or CLI ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
When I try to use the web GUI it loads for some time then it says no connection. When I try to use the CLI it is just blank, and I have the right CLI settings and I use putty. After I have factory reseted, I try to use 192.168.1.254 but it's not working
balaji.bandi
BB
Im gonna try that.
What I mean with 100 up and down is 100mbps up/upload and 100mbps down/download through the ethernet ports
as per the model its only 100MB, so you are good in terms of connection.
BB
Tanks. Your solution worked. But is there some way i can make it go from 100 to 500mbps?
The switch is 100MB as per the specification, so check you can use uplinks they are 1GB
BB
I don't exactly know how to do that, so if you could send me a tutorial, that would be great.
Do you know anything about igmp proxy? And how to turn it on?
Check-in Front of the switch there are 2 ports Modular, you need to buy GLC-T 1G Ethernet to work for 1GB network.
IGMP Proxy, I am not sure these models support, since these are SMB switches.
for IGMP look at the admin guide :
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
BB
Would this: Fiberworks 1G SFP 1000Base-LX LC Duplex. Work?
https://www.finn.no/179234651
                     - Correct operational  use of none-cisco (foreign) SFP's can not be guaranteed : https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/Cisco_300Sx_v1_4_AG.pdf , start reading from Displaying Optical Module Status
 M.
       Beauty and terror
      Just keep going
       No feeling is final
YES and NO. I would advise using Cisco SFP (even it is refurbished) for easy installation and working conditions.
Note: some devices in cisco do not accept 3rd party SFP.
BB
