WIC-1T to HWIC-1T connection
Marcogiraldo86
I am building an home laboratory with some routers.
I'd like to know if can I connect Cisco 1841 with WIC-1T interface to a Cisco 2921 with HWIC-2T interface?
The true cable should be CAB-SS-2660X?
That is for cross-connecting a 60-pin to a 26-pin WIC, which should work fine. You would need to make one side DTE and the other side DCE.
https://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/7261-wic-2t.html
marce1000
  - Review this thread : https://dvswitch.groups.io/g/Quantar-Bridge/topic/72936069
 M.
they talked about other type of cable.
I need help to know if two serial port with different interface type can run with cross cable cross that have code: CAB-SS-2660X
