WS-C3560-48PS SFPs compatible with 2960-S switches
Gerry Egan
I need to replace an older 3560 with a new 2960-S and am wondering if the SX SFPs I already have will be compatible with the 2960-S.
Switch#sh inventory
NAME: "1", DESCR: "WS-C3560-48PS"
PID: WS-C3560-48PS-S   , VID: V04, SN: CATXXXXXXXXX
NAME: "GigabitEthernet0/2", DESCR: "1000BaseSX SFP"
PID:                     , VID:    , SN: H11K611
NAME: "GigabitEthernet0/4", DESCR: "1000BaseSX SFP"
PID:                     , VID:    , SN: H11K776
Here is the show inventory, I cannot find any way to get the part numbers of teh SFPs so if you have that command please also let me know.
Thanks and regards.
Gerry Egan
    Should be fine , shows as a Cisco sfp .
7 Replies 7
Leo Laohoo
Nope.  If the SFP does not have "Cisco" written on it it's not.
The S/N does not look familliar so I'm suspecting you're using a 3rd party component.
The SFPs are Cisco original products. We had another identical switch fail and they had Cisco originals installed with a very similar serial number.
I've never seen a serial number like that before.
OK, so if the SFP are Cisco then it will work on the 2960S.
glen.grant
Does a "show idprom interface g0/2"  show anything different?  Usually that will show all the info.
Hi Grant thanks for your input... here is the output of that command:
Switch#sh idprom interface gigabitEthernet 0/2
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x01 0x20 0x40 0x0C 0x00
Encoding              :   0x01
BR_Nominal            :   0x0C
Vendor Name           :   CISCO-FINISAR
Vendor Part Number    :   FTRJ-8519-7D-CS
Vendor Revision       :   0x20 0x20 0x20 0x20
Vendor Serial Number  :   H11K611
Switch#sh idprom interface gigabitEthernet 0/4
Identifier            :   0x03
Connector             :   0x07
Encoding              :   0x01
BR_Nominal            :   0x0C
Vendor Serial Number  :   H11K776
Switch#
What do you think?
If the SFP is already working in an existing Cisco device (in your case 3560), it should work just fine in a 2960.
GLC-SX-MM is supported on the 2960s series.
see table-15 in this link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
