03-09-2015 09:53 AM - edited 03-18-2019 04:09 AM
Recently I've had a string of WAN 'blips' that caused the phones to fall back to the gateway. Most of them re-register back to CallManager after the outage is fixed, but it seems as though a few get stuck on the gateway...i've watched the timer count down and it just restarts the countdown. The 9971 and 8961 phones, though, go right back with no issue...
Has anyone come across this before?
Solved! Go to Solution.
03-09-2015 01:19 PM
No, I have not come across any situation like that.
Just wondering how long it remains stuck on the SRST Mode after the WAN link is restored?
If it is stuck for a prolonged period (more than 15 - 20 mins) then I would want to upgrade the firmware and see if that makes any difference.
03-09-2015 01:19 PM
03-10-2015 07:57 AM
thank you for your response ,
it stays indefinitely in srst mode.
the gateway(2901) version is 15.3
03-10-2015 08:56 PM
What firmware version does the two phones have?
03-11-2015 02:35 AM
the firmware version is "sip 78xx.10.2.1.12sr1-4"
03-11-2015 04:50 PM
That is the latest firmware I used for our customers as well. No issues reported similar to what you are experiencing.
I'd suggest you do take packet capture on the phone side (phone that is having the issue) when re-producing the problem.
11-29-2015 01:37 AM
Hello All,
Any one having this issue ?? ..
we are facing same problem .. can someone update us if there was any procedure done to fix this issue ?
Thanks A lot
Ahmed Salah
