Book permanent Conference on MCU via TMS and TMSXN
martin1.plank
Level 4
Level 4
Hallo all,
I've configured serveral permanten conferences on MCU 8420.
Now I want book these conferences via TMS and TMSXN.
How can I do so?
kind regards
Martin
Martin Koch
From how I see it its still not possible, even with the latest TMS versions.
Its either booking or pre defined conferences. At least they can be managed now with the
conference control center, but at least I am not aware of any way to use these within
scheduling.
I would recomend you take it with your Cisco Channel to file a feature request.
thobonho
And what about adding Rooms in TMS (Add systems, Advanced Settings) ?
By doing this, you will be able to associate a room to a permanent meeting and since a Room has a System ID in TMS, it will be bookable as other systems.
If you add 2 other systems to a booking with that solution, the MCU will cal itself, so you will see a loop. I'm using CPL to block the MCU from calling itself.
Regards, Paul
By adding resources I can integrate virtual rooms.
Do I have to use CPL to block the mcu from calling itsef, or is there a parameter on mcu config to do so as well?
