C 20 Camera not working
Yasir Vistro
we have c 20  . Camera Orange Light Continous ON but Camera not show self View .
we plug directly with LCD but same status .
Yasir Vistro .
Yasir Vistro
mubakhta
Level 4
Level 4
Hi Yasir,
We have identified a known issue with the Precision HD 1080p 4x cameras. Please go through this document for more details :
https://supportforums.cisco.com/docs/DOC-25123
The issue is due to the camera not booting up. You will need to manually reboot the camera as mentioned in the document above. You can use the following files to manually upgrade the camera :
For USB      :       https://supportforums.cisco.com/docs/DOC-25088
For Serial     :       https://supportforums.cisco.com/docs/DOC-25127
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Ravi Yadav
Level 4
Level 4
Hi Yasir,
As said by Mr. Akhtar, its known issue , if you face any issues upgrading the unit open a TAC case and we will assist you.
Also make sure that the unit is upgraded to TC 5.1.3
Ravi Kr.
amehla
Hi Yasir,
this issue has been identified with 4X camera's
Please find the attached document for complete recovery procedure.
Regrads,
Amit Mehla
