c 60 with 3 camera and content Server
Yasir Vistro
hi All
We have C 60 with software version TC3. We connect 3 cameras. 1st  2 Camera connect on HDMI working fine, 3rd one  connect on BNC  how I select the source to Camera 3 ?
We have contect Server, is it any option on contect  Server  Fix the timing  Start recoding and End Recoding ?
Yasir Vistro
Yasir Vistro
16 Replies 16
Magnus Ohm
Hi Yasir
For the last question do you mean setup a fixed start time and end time?
I guess you can do this with TMS by scheduling the recording, or it might be possible to write a script to make the C60 API end the call after a certain amount of time.
But I am not sure if this is what you want?
/Magnus
Yes Magnus  you are right .  we  need  this
Yasir Vistro
Yasir Vistro
All
kindly responce
Yasir Vistro
Yasir Vistro
Yasir,
Can you please clarify what is BNC?? I am not sure which input you're referring to.
Please explain.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Use the command below to choose the right input you are using, you should be either choosing Composite or YC depending on which you are using,
xConfiguration Video Input Source 3 Connector:
or, you can use the remote controller to change it.
i applied this commond but but help full .
Yasir Vistro
Yasir Vistro
Yasir, your answer is not clear to me, did it work or do you still struggle?
Its not one command its three different options you have. "Source 3" has 3 different options,
DVI, Composite or YC.
SO you should test any of the three commands:
xConfiguration Video Input Source 3 Connector: DVI
xConfiguration Video Input Source 3 Connector: Composite
xConfiguration Video Input Source 3 Connector: YC
DVI is unlikely as you said you use BNC, if its composite (pal/ntcs) it will be Composite if its S-Video (two bnc) it should by YC.
But, what kind of camera do you use? The BNC port of a PrecisionHD cam (SDI-HD) can not be connected to the
BNC ports of a C60 (Video-SD), so you have to have the right output signal (Composite/S-Video) on your camera.
If you use a PrecisionHD cam, you might be able to use a HDMI>DVI cable.
BNC is just a way to connect a cable, it does not say what is transmitted over it :-)
Btw, I would recomend to upgrade the software as TC3 is quite outdated.
thanks Martin
I brief you complete scenario .
We have c 60 with 3 (12x) 1080p Camera.
Video IN
1st Camera .        HDMI
2nd Camera          HDMI
3rd Camera          BNC
Camera Control
1st camera Connect with Codec C 60 and other 2  Control via daisy chain .
I change the video Input PC to 3rd camera but Camera not show the self view.
Hope you understand the scenario. Thanks
Yasir Vistro
Yasir Vistro
Yasir,
The BNC output of the 12x camera is a HD-SDI output.  The C60 does not have a HD-SDI input, what C60 has is only the Y-C or the composite input.  So you cannot connect the 12x camera HD-SDI(BNC) output to the C60, unless you can find some sort of HDSDI-video converter etc, but I do not think you would want to do that.
Like I wrote before, its the same connector, but the signal is not the same!
I would try to get a HDMI to DVI cable and then select DVI and digital for this port.
Please rate the answers and set the thread to answered if it is!
Dear Martin
the length between Codec and 3rd camera approx 80 meter .
Yasir Vistro
Yasir Vistro
Yes Tang
i Plugged the Camera On Y-C port .
Yasir Vistro
Yasir Vistro
Dear All
kindly find below exact scenario.
Yasir Vistro
Yasir Vistro
hi,
as mentioned earlier, the camera BNC is a HD-SDI output, you cannot connect this directly to the Y-C input.
you can connect the camera HDMI output to the DVI input as what Martin suggest above, but if that is the case, then you might also have an issue if you need to send a PC source.
Also, not sure why you are connecting your smart TV to the composite output of the codec, why not use the DVI output?
