C40 boot error
Hello, team!
I have strange issue with C40.
I can't boot.
I have check messages via console and found this one:
AMERICA> boot
Configure FPGAs
FPGA configuration failed
Setting up Davinci HD (00.10.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.11.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.12.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.13.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.14.00)... 675Mhz       [DONE]
Setting up Davinci HD (00.15.00)... 675Mhz       [DONE]
Copy /flash/active/arm/rootfs to 0x03000000... File not found
Error: filesize must be > 0
Copy /flash/active/arm/kernel to 0x02000000... File not found
Copy /flash/active/arm/u-boot.bin to 0x01000000... File not found
Copy /flash/active/kernel to 0x01000000... File not found
Copy /flash/active/rootfs to 0x02000000... File not found
Copy /flash/active/c40.dtb to 0x03000000... File not found
Unmounting yaffs2 mount point /flash
Wrong Image Format for bootm command
ERROR: can't get kernel image!
AMERICA>
Is it possible to resolve this problem locally? Or it prefer to replace device via Cisco?
Be ready
I think you have an issue with the hardware, more specifically, the audio DSPs.
Is in the console log.
Jun 21 14:43:18 (none) main: uhpihost: Can't boot dsp 3
Jun 21 14:43:18 (none) main: uhpihost: Can't boot all dsps
Jun 21 14:43:18 (none) main: Backtrace:
So main application is killed because we cannot start these DSPs.
I am afraid this will be an RMA to get a new unit....
14 Replies 14
Danny De Ridder
the image is corrupted.
First step would be to check whether you still have another image on the box.
Can be checked doing :
AMERICA>selectsw
If you see another image which is not active, you can select that image and try to boot.
AMERICA> selectsw image1
(should image2 be active, otherwise choose 2 if image1 is active).
That can possibly recover the unit to previous release.
Hello Danny!
I have try, but it does'n help.
AMERICA> selectsw
AMERICA> boot
Configure FPGAs
As I understand, I haven't second image on flash:
AMERICA> yls -l
opendir failed, No such entry
AMERICA> yls -l /flash
image2                             2048   520 directory
lost+found                         2048     2 directory
active                                6   513 symlink -> image1
Be ready
Indeed, so the easy procedure of trying other image cannot be done.
The next step would be to load image via the u-boot (which is the mode you are in when you see the AMERICA prompt) prompt. You need to have a tftp file server with the image you want to load.
Let me dig up the procedure.
It is located here : https://supportforums.cisco.com/docs/DOC-27345
The procedure explains how to load a package from a tftp server.
Can you try that?
Danny.
I made it.
But in a process I saw this one:
NAND erase: device 0 whole chip
Skipping bad block at  0x00580000
Skipping bad block at  0x0fe20000
Skipping bad block at  0x166c0000
Skipping bad block at  0x20580000
Skipping bad block at  0x38fc0000
Skipping bad block at  0x55a40000
Skipping bad block at  0x7ca40000
Erasing at 0x7ffe0000 -- 100% complete.
Is it ok, or may be it mean that flash is corrupted?
Full output:
AMERICA> run pkgex
BOOTP broadcast 1
DHCP client bound to address 192.168.1.23
OK
Mounting yaffs2 mount point /flash
Mount point name already used
Using TSEC0 device
TFTP from server 192.168.1.10; our IP address is 192.168.1.23
Filename '/s52011tcnc5_1_5.pkg'.
Load address: 0x2000000
Loading: #################################################################
         91 MB received
         #####T ############################################################
done
Bytes transferred = 148485759 (8d9b67f hex)
Copy pkgextract.elf from NOR flash to 0x1000000
## Starting application at 0x00042ff8 ...
Buildtime: Oct  1 2012 08:08:58
Write version information to /flash/image1/version
Extract             /flash/image1//pki/signcert.pem
Extract             /flash/image1/endeavour/pkgextract.elf
Extract             /flash/image1/endeavour/u-boot.bin
Extract             /flash/image1/endeavour/endeavour.pkg ....................
Extract             /flash/image1/S01762.bin.wrapper
Extract             /flash/image1//nandi.pkg ..
Extract             /flash/image1//fu
Extract             /flash/image1//sangam.pkg ..
Extract             /flash/image1//rover.pkg ..
Extract             /flash/image1//www.img
Extract             /flash/image1//web.img .
Extract             /flash/image1/partitions.conf.d/web.conf
Extract             /flash/image1//sounds.img .
Extract             /flash/image1//web2tsh.img
Extract             /flash/image1//posters.img
Extract             /flash/image1//partitions.conf.d/main
Extract             /flash/image1//rwfs.conf
Extract             /flash/image1//target.lst
Extract             /flash/image1//slaveapps.img ..
Extract             /flash/image1//partitions.conf.d/gui
Extract             /flash/image1//gui.img ................
Extract             /flash/image1//apps.img ......
Extract             /flash/image1/partitions.conf.d/extra
Extract             /flash/image1/kernel .
Extract             /flash/image1/rootfs ..
Extract             /flash/image1/extra.img ..........
Extract             /flash/image1/u-boot.bin
Extract [exe]       /flash/image1//postinstall.d/rwfs.hook
Extract             /flash/image1/vcinfo.txt
## Application terminated, rc = 0x0
Reprogram NOR from /flash/image1
Un-Protected 1 sectors
. done
Erased 1 sectors
Copy /flash/image1/bootsw to 0x01000000... File not found
Error running 'loader'
Copy /flash/image1/pkgextract.elf to 0x01000000... File not found
File /flash/image1/S01710.bin.wrapper not found
Be ready
Not all files got written/extracted. The error says : "Application terminated, rc = 0x0"
Could be that we have a faulty flash which got the image corrupted in the 1st place.
I looked at u-boot commands to see whether there are any "flash check commands" but could not see anything obvious.
Asked engineering whether there are commands we can run to to a flash check.
I overlooked one important thing : you are loading the wrong image! s52011tcnc5_1_5.pkg is for SX20 and we need to get image for a C40 which would be s52000tcnc5_1_5.pkg.
Please try to load the C40 image instead.
Good catch Danny !! I believe that should be the last hiccup !!
Mubashshir Akhtar
TelePresence Solution Group
Thanks Mubashshir Akhtar
You was right. I use wrong image
I try to use s52001tcnc5_1_5.pkg(sorry, but I must use NC software).
It loads, but I can't access to terminal via web-GUI or via Telnet. On TV I can see short 1-minute moovie "White Cisco logo on black font." After that jost "no signal".
AMERICA> dhcp
BOOTP broadcast 1
AMERICA> setenv serverip 192.168.1.10
AMERICA> setenv tftp_path
AMERICA> setenv saturnpkg s52001tcnc5_1_5.pkg
AMERICA> run pkgex
BOOTP broadcast 1
OK
Using TSEC0 device
Filename '/s52001tcnc5_1_5.pkg'.
Loading: #***output omitted***#
         91 MB received
         183 MB received
done
Bytes transferred = 215634326 (cda5196 hex)
Extract             /flash/image1/pkgextract.elf
Extract             /flash/image1/bootsw
Extract             /flash/image1//arm/xpe.img
Extract             /flash/image1/fpga/s01776fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01775fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01774fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01760fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01746fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01745fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01753fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01750fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01739fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01737fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01736fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01727fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01726fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01722fpgaappl.dcf.wrapper
Extract             /flash/image1/fpga/s01758fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01754fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01728fpgaconfig.rbf.wrapper
Extract             /flash/image1/fpga/s01721fpgaconfig.rbf.wrapper
Extract             /flash/image1/arm968_h264fhddec_60fps.out
Extract             /flash/image1/arm968_h264enc.out
Extract             /flash/image1/arm968_h264enc_multichip.out
Extract             /flash/image1/arm968_h264dec.out
Extract             /flash/image1/arm968_h264fhddec_60fps_parser.out
Extract             /flash/image1/arm968_h264enc_fullhd.out
Extract             /flash/image1/arm968_h264enc_fhd_multislice.out
Extract             /flash/image1//arm/video.ccf .
Extract             /flash/image1/namsw.bin
Extract             /flash/image1/audio.ccf .
Extract             /flash/image1//arm/partitions.conf.d/osd
Extract             /flash/image1//arm/osd.img ..........
Extract             /flash/image1/S01710.bin.wrapper
Extract             /flash/image1//arm/apps.img
Extract             /flash/image1//arm/u-boot.bin
Extract             /flash/image1//arm/extra.img
Extract             /flash/image1//arm/kernel
Extract             /flash/image1//arm/rootfs ...
Extract             /flash/image1//arm/partitions.conf.d/main
Extract             /flash/image1//vmlinux ..
Extract             /flash/image1//devel.img ...
Extract             /flash/image1//partitions.conf.d/devel
Extract             /flash/image1//partitions.conf.d/extra
Extract             /flash/image1//kernel .
Extract             /flash/image1//dtb7
Extract             /flash/image1//dtb6
Extract             /flash/image1//dtb5
Extract             /flash/image1//c40.dtb
Extract             /flash/image1//dtb3
Extract             /flash/image1//dtb2
Extract             /flash/image1//rootfs ...
Extract             /flash/image1//extra.img ........
Extract             /flash/image1//apps.img ..................
. done
Erased 1 sectors
Copy /flash/image1/bootsw to 0x01000000...      [DONE]
Write /flash/image1/bootsw (669720) to NOR flash
NOR allready contains correct data
Copy /flash/image1/pkgextract.elf to 0x01000000...      [DONE]
Write /flash/image1/pkgextract.elf (122452) to NOR flash
Program hwmon, read file from /flash/image1/S01710.bin.wrapper...
String is: File last modified: 2012-04-17 13:13:33, MD5: 3450236d34642e4137a10e17a25b4eb1, description:"Version:45"
HWMON: Updating from version 45 to version 45
HWMON: Version on monitor is newer or the same, not updated!
AMERICA> boot
Configure FPGAs        -
Copy /flash/image1/arm/rootfs to 0x03000000...  [DONE]
Copy /flash/image1/arm/kernel to 0x02000000...  [DONE]
Copy /flash/image1/arm/u-boot.bin to 0x01000000...      [DONE]
Copy /flash/image1/kernel to 0x01000000...      [DONE]
Copy /flash/image1/rootfs to 0x02000000...      [DONE]
Copy /flash/image1/c40.dtb to 0x03000000...     [DONE]
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   Linux-3.0.14-202
   Created:      2012-09-11  13:51:37 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    2228578 Bytes = 2.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name:   TANDBERG rootfs
   Created:      2012-09-11  14:03:12 UTC
   Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
   Data Size:    7613587 Bytes = 7.3 MiB
## Flattened Device Tree blob at 03000000
   Booting using the fdt blob at 0x3000000
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 1e7eb000, end 1ef2dc93 ... OK
   Loading Device Tree to 007fb000, end 007ff7bc ... OK
Using MPC8347 Saturn PPC machine description
Linux version 3.0.14-202 (henribak@rdbuild11) (gcc version 4.6.1 (crosstool-NG hg_unknown@20111018.110132) ) #1 PREEMPT Tue Sep 11 15:51:34 CEST 2012
Found initrd at 0xde7eb000:0xdef2dc93
bootconsole [udbg0] enabled
setup_arch: bootmem
mpc8347_saturn_ppc_setup_arch()
Found FSL PCI host bridge at 0x00000000e0008500. Firmware bus number: 0->0
PCI host bridge /pci@e0008500 (primary) ranges:
MEM 0x0000000090000000..0x000000009fffffff -> 0x0000000090000000
MEM 0x0000000080000000..0x000000008fffffff -> 0x0000000080000000 Prefetch
  IO 0x00000000e2000000..0x00000000e20fffff -> 0x0000000000000000
arch: exit
Zone PFN ranges:
  DMA      0x00000000 -> 0x00020000
  Normal   empty
  HighMem  empty
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00020000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: basemount=/dev/mtdblock1 console=tty0,38400 mainboard=0xc1 videoboard=0xd3 audioextboard=0xffffffff u-boot=2010.06-108 fips=1
Registered maintag: 0xc1
Registered videotag: 0xd3
Registered audioexttag: 0xffffffff
fips mode: enabled
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 507564k/524288k available (4336k kernel code, 16724k reserved, 228k data, 133k bss, 168k init)
Kernel virtual memory layout:
  * 0xfffcf000..0xfffff000  : fixmap
  * 0xff800000..0xffc00000  : highmem PTEs
  * 0xff6fb000..0xff800000  : early ioremap
  * 0xe1000000..0xff6fb000  : vmalloc & ioremap
SLUB: Genslabs=15, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:512
IPIC (128 IRQ sources) at e1000700
clocksource: timebase mult[5000002] shift[22] registered
Console: colour dummy device 80x25
console [tty0] enabled, bootconsole disabled
U-Boot 2010.06-108 (Oct 01 2012 - 08:08:23) MPC83XX
Reset Status:
CPU:   e300c1, MPC8347_TBGA_EA, Rev: 3.0 at 600 MHz, CSB: 200 MHz
I2C:   ready
DRAM:  DDR2 RAM: 512 MiB
RAM data bus test       [PASS]
RAM address bus test    [PASS]
FLASH: 4 MiB
NAND:  2048 MiB
*** Warning - bad CRC, using default environment
RTC:   2013-06-21 (Friday) - Time: 13:02:54
PCI Video Processor Detection   [PASS]
Saving new default environment
Erasing Flash...
. done
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
America
       SN: F1AV04F00030
       Object level: C1
America main board
       Rev: B
       SN: PB0695236
       Object level: A4
       MAC: 00:50:60:0D:BB:3D
America video input board
       Rev: D
       SN: PB0695187
       Object level: A2
Net:   TSEC0, TSEC1
Hwmon: 45
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  0
Configures yaffs mount /flash: dev 0 start block 0, end block 16383
Configure FPGAs        -
Copy /flash/active/arm/rootfs to 0x03000000...  [DONE]
Copy /flash/active/arm/kernel to 0x02000000...  [DONE]
Copy /flash/active/arm/u-boot.bin to 0x01000000...      [DONE]
Copy /flash/active/kernel to 0x01000000...      [DONE]
Copy /flash/active/rootfs to 0x02000000...      [DONE]
Copy /flash/active/c40.dtb to 0x03000000...     [DONE]
setup_arch: bootmem
arch: exit
Zone PFN ranges:
  Normal   empty
  HighMem  empty
fips mode: enabled
NR_IRQS:512
login: admin
Welcome to the Cisco Telepresence maintenance shell.
Type 'help' or '?' for help.
Be ready
You are getting further now, but the image crashes. Could be hardware or software.
The system enters maintenance mode.
At the prompt, can you do :
log
and collect all the output to a file and send it over?
Danny.
Sure
You can check attach.
Be ready
Thanks a lot for a help, Danny!
Be ready
I have C40
I need these file
pkgextract.elf
u-boot,
Please send me via emial  :  boyahensem@gmail.com
hi:
    I have a  c60 ,
I  need these files:
pkgextract.elf
u-boot,
PLEASE  SENT MY EMAIL  :  zgf926@163.com
