C40 Factory Reset How To
Josh Adamson
I have a client that has locked themself out of the device for ssh and https.  They would like to factory reset the unit but not sure how to accomplish without being able to login.  Any assistance is appreciated...thanks
Jens Didriksen
Level 9
Level 9
You need to use a serial connection, see page 24 of the troubleshooting guide for "how to":
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc6/troubleshooting_guide/tc_troubleshooting_guide_tc60.pdf
or, alternaltively, open a TAC case - still need that serial connection though.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
Thanks for the info and issue is now resovled!!!
What do you mean by "locked themself out"?  Have they just forgotten the password, or have they turned the network services for ssh and https off?  If it's the latter, they can be turned back on via the menu (assuming the menu isn't password protected as well).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
