Can a SparkBoard call using H.323
Have a Spark registered SPARKBOARD and I need to have it be able to call customer that is still on H.323 Polycom endpoint.  I have tried putting in the IP address and that does not work.  Found a doc that indicated that I should be able to type in "ip" and then be prompted for the IP address but that does not seem to work anymore either.  Tried h323@<ip address> but that did not work either.
Any solution?
Found the following link:
https://collaborationhelp.cisco.com/article/en-us/7ej8gq
No support for anything other than SIP.
5 Replies 5
As you've noticed in the linked document, Cisco Spark Board registers to Cisco Spark in the Cisco Collaboration Cloud, which is SIP only. However, if you or the endpoint your calling utilizes a VCS or Expressway, it could interwork between SIP and H323.
Joe Vallender
Level 3
Level 3
Is that Polycom endpoint registering to a gatekeeper?  If so, it may support SIP to H.323 interworking.
ooops the link was already posted. Sorry for that - I cannot remove my entry...
