(CE9.3) UnSet the button on touchpad
QNZenX
Dear all,
I'm trying to Unset the button to show on the group button, for example:
2 groups: left, right.
in each group I have: 5 button
But it does not work, can someone help me? Thank you.
function setbutton(event){
xapi.command('UserInterface Extensions Widget UnsetValue', value == 'widget_left');
xapi.command('UserInterface Extensions Widget UnsetValue',  value == 'widget_right');
The API command is:
xCommand UserInterface Extensions Widget UnsetValue WidgetId: "widget_left"
So, if I'm translating it correctly, the xAPI command would be:
xapi.command("UserInterface Extensions Widget UnsetValue", {WidgetId: "widget_left"});
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
You haven't specified the widgetId
Wayne
Dear Wayne,
Thank you for your replies, I think I already put the widgetID in, or may be I my command is wrong?Screen Shot 2019-09-16 at 8.48.49 AM.png
The API command is:
Wayne
