CE9.X Endpoint, api command SIP TlsVerify to OFF ?
Georg Kehrer
Level 4
Level 4
Dear all
Does someone has the Idea what is the api command to set TlsVerify to Off ??
is it only possible via Web Interface ?
Thanks for any Feedback.
Best Regards
Georg
asri.zainal
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce98/collaboration-endpoint-software-api-reference-guide-ce98.pdf
According to CE9.8 API reference Guide, it is only possible via Web Interface.
I use the supported command matrix a lot as apparently there are some still a number of actions that is only supported via Web Interface, not via API.
Thanks for your Feedback, Ok,
Problem is if you need change a setting on ~170 Endpoint, it's not easy
Best Regards
Georg
ouch, that's definitely a pain.
Are all these endpoints connected to CUCM or configured as standalone?
yes at the moment registered on CUCM, but in the future will be registered in the Cloud (not Cisco) and than I need to set this TlsVerify to OFF
