04-22-2021 01:27 PM
Hello all. I need to change the hostname of a VCS-E. I know how to change it but want am interested in knowing what I may potentially break. It is currently just using a self-signed cert. My zone traversal uses the IP address.
Any one have any insight for me?
Thank you in advance!
Solved! Go to Solution.
05-26-2021 06:27 AM
Just to close the loop on this.
We were able to change the hostname and update the DNS record while maintaining the original DNS record. This allowed us to keep all of the systems registered as we migrated. As a part of this we also installed TA certificates on the VCS pair.
04-22-2021 06:18 PM
Never seen a VCS-E deployment using self signed certificate. if you change name, existing certificate need to regenerated or get a new cert with the new name in the san filed . If using TLS for travel zone, this could break the zone.
04-23-2021 07:08 AM
You're correct, it isn't self-signed but the default certificate that is installed at installation.
05-26-2021 06:27 AM
