03-31-2013 01:07 AM - edited 03-18-2019 12:51 AM
Dear Experts
I have a problem for E20 which is working fine with cisco IP phones . When i do a call from Cisco E20 to digital or analouge phone then i disonecct the phone lines it is still connected for Example I made a phone call from Cisco e20 to Any Digital phone and I disconect from Cisco E20 but Digital phone shows call is connected and ringing ) for ( digital and analouge phones) and the name of the caller ID is not displayed. For Cisco IP phones , it is working so fine with digital and analouge phones and the name is displaying . Please i need a help , because i do my best without any results
Thank you
Islam Kamal
03-31-2013 02:24 AM
Could you provide more details about the call flow along with infrastructure devices involved.
What is the version on E20 ?
Sent from Cisco Technical Support Android App
03-31-2013 06:54 AM
Dear
E20 s/w TE4.0.0.246968 & cisco call manager v8.6 . call flow Cisco E20 - CCM- MGCP gateway- E1 trunk -Ericsson PBX-
digital or analouge phone.
03-31-2013 08:39 AM
Hi Islam,
seems like your far end device ( digital and analouge) is not responding to the BYE message from E20. Do the CUCM responds to the BYE message from E20 ?
in this case call will be disconnected after sometime.
can you capture SIP logs for call to check ?
03-31-2013 09:37 AM
thank you for your help , but why this problem not happen with other Cisco IP phone when do calls for analouge and digital phones
. I need also please to tell me any troubleshoot way to capture the logs which you will need . and please tell me why the caller name does not appear , although other cisco ip phones caller name appear ehen do calls for digital and analouge phones.
Thank you
04-01-2013 11:15 AM
Dear
Any ideas
thank you
04-01-2013 11:41 AM
hi Kamal,
1. Take a ssh or telnet session of E20 using PUTTY.
2. Make sure to enable all session output.
3. Type the command: xconfig
4. Xstatus
5. Log output on
6. Now make a call and recreate the issue.
7. After some time, disconnect the call.
04-01-2013 04:19 PM
Thank you i will do this test and i will tell you the feeedback
04-02-2013 12:40 AM
Hi Ismal,
in addition to the process as suggested by Amit add this part after the xstat and xconf and log output on.
log ctx SipPacket debug 9
Make a call and keep running until you have recreated the problem
Disconnect the call
log ctx SipPacket debug off
Log output off
This will give better call details
Let us know the results.
Ravi kr.
04-02-2013 11:21 AM
if E20 is registered to CUCM, then run RTMT and collect logs from there and see the BYE message ever sent to E20
04-06-2013 04:42 AM
04-06-2013 12:58 PM
please any updates .
Thank you
04-07-2013 03:30 AM
Hi Islam,
As requested before log output on
would have given us a delated logs of the sip packet flow
this log does not show and Bye however its does show teh local disconnect Ok
however we cannot confirm if there was any diconnect ACk message message received form the far end
350329.52 MC I: Mc::CallResponse(p=6,s = 0, st = 2) ok: 2,0,0,0
350329.55 RTP I: Rtp_Ready_doRTPSourceMuteReq(app=0,strm=33) source unmuted
350329.55 APPL I: ApplFac:: <- MC:CallResponse(p=6,s=0,st=2) reason=0/' 2,0,0,0'
350329.56 APPL I: ApplFac:: -> MC:SetLayoutRequest(p=1 ch=1) 6 2 0 0 10000 10000 1 0
350329.57 APPL I: ApplFac:: -> MC:SetLayoutRequest(p=6 ch=2) 1 1 0 0 10000 10000 1 0
350329.58 DATACTRL I: DataGateCfgReq(og=5) hdlc=no
350330.11 MC !ER TransactionActionStorage::cnfAction no match for Modify Mixer id(50)
350330.55 APPL I: ApplFac:: -> EVENT:CallSuccess(p=6)
350341.10 APPL I: ApplFac:: -> CUIL:CallLogCreatedInd logType=0 logTag=349
350341.11 APPL I: ApplFac:: -> CUIL:CallLogDeletedInd logType=1 logTag=348
350341.11 APPL I: ApplFac:: -> CUIL:CallLogCreatedInd logType=1 logTag=349
350341.12 APPL I: ApplFac:: -> CUIL:CallLogDeletedInd logType=2 logTag=348
350341.12 APPL I: ApplFac:: -> CUIL:CallLogCreatedInd logType=2 logTag=349
350341.13 MC I: Mc::disconnectResponse(p=6) ok
350341.23 Bfcp W: ERROR.. unknown ROLE!
350341.23 APPL I: ApplFac:: <- MC:DisconnectResponse(p=6) reason=0/''
350341.28 MC I: Mc::DeleteParticipantResponse(c=6) ok
Ravi Kr.
04-07-2013 05:21 AM
Thank you for your support , promise to update my log . What about the delay for hunging up to do the call , is there any explanation?.
Thank you
04-09-2013 02:49 AM
