Cisco Expressway 8.7 Compatibility with CUCM 10.5.2
Hi Guys
Do someone know if Cisco Expressway 8.7 has any compatibility issues when deployed with Cisco Unified Communication Manager version 10.5.2.
Used services on the Expressway cluster is MRA & B2B .
Ahmed
8 Replies 8
Manish Gogna
Hi Ahmed,
Expressway X8.7 does work with CUCM 10.5 however there are certain features introduced in this version which require CUCM 11.0 as explained in the following link ( MRA information included )
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/release_note/Cisco-Expressway-Release-Note-X8-7.pdf
Following is the doc showing integration info for X8.7 and cucm 8.x-11.x
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-7/Cisco-Expressway-SIP-Trunk-to-Unified-CM-Deployment-Guide-CUCM-8-9-10-11-and-X8-7.pdf
Manish
- Do rate helpful posts -
Thanks Manish
Hi Manish,
do MRA feature of expressway 8.7 work with CUCM 9.1.2?
Cheers
Vigeesh
Hi Vigeesh,
Yes, it does
Manish
Please advice if VCS X8.5.1 has compatibility issues when deployed with Cisco Unified Communication Manager version 11.0.1
Mick
Hi Mick,
The deployment guide for VCS X8.5.1 shows compatibility with CUCM 9.1.2 SU1 and later and the deployment guide for X8.7 shows it explicitly for 11.x as well
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-5-1.pdf
Interestingly the intermediate X8.6 versions shows explicit support upto 10.x version
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-6/Cisco-Expressway-SIP-Trunk-to-Unified-CM-Deployment-Guide-CUCM-8-9-10-and-X8-6.pdf
Since the X8.5.1 was released more than a year ago i would encourage upgrading to 8.7 version as it clearly points out support for 11.x version of cucm.
Manish
[+5] to Manish.
I do not think there would be any issues.
we have some deployments using VCS Ctrl version 8.1.1 with CUCM 10.5.2 and expressway 8.5 and 8.7 with CUCM 10.5
The link shared by Manish shows compatibility as attached.
regds,
aman
Thanks for confirming it Aman.
Manish
