Cisco IX5000 supports H.323
doanhuuhiep
Hi all.
I have a question that Cisco IX5000 supports H.323 protocol.
There is only SIP in the datasheet I checked. But, my customer don't want to buy CUCM. They only want to call point-to-point between 2 IX5000.
Thanks.
A CUCM as a call control and provides SIP signaling for TelePresence System IX5000 is required for the system to work. A CUCM is needed for the system to get its configuration via TFTP.
You can find the document provided on the link below:
http://www.cisco.com/c/en/us/td/docs/telepresence/ix5000/first_time_setup/ix5000_first_time_setup.html
regards,
Acevirgil
regards,
Acevirgil
Yes it can dial via H323 but not directly. Expressway C/E will do the conversion of SIP to H323
