Cisco Meeting Server (Acano) recording not working
al_vargas
I'm running a single server deployment lab on VMware. Everything is running fine, but recording.
I have done the following:
1) Generated and issued internal CA certificates
2) Configured recorder by CLI with certificates, listen to unbind port 8443
3) Configured by API the recorder URL https://127.0.0.1:8443
4) Created callLegProfiles and callProfile for allowing manual recording
5) Created dmtfProfile with startRecording and stopRecording patterns
6) Set up those profiles as default system profiles
I got the following error message in Status > General:
Recorder "https://127.0.0.1:8443" unavailable (connect failure)
By running openssl s_client -connect I do confirm port 8443 is closed. So I'm assuming recorder is not up. I have already tried versions 2.0.9, 2.1.2 and 2.1.3 without success.
Am I missing something? Has anyone been able to put it working?
The license command output is:
acano> license
Feature: callbridge status: Activated expiry: 2117-Feb-13 (36511 days remain)
Feature: turn status: Activated expiry: 2117-Feb-13 (36511 days remain)
Feature: webbridge status: Activated expiry: 2117-Feb-13 (36511 days remain)
Feature: recording status: Activated expiry: 2117-Feb-13 (36511 days remain)
36 Replies 36
That is correct.  Here is an example for settings up the Recorder: Configure Recorder in CMS/Acano Call Bridge.
I'm having the same problem as Nguyen Thanh ,
'unable to start recording --- recording limit reached' But I do have the recording license in all three Call bridge servers. Any clues as to what else might cause this?
I have checked DTMF, Call and Leg Profiles and they all seem to be fine, same with certs.
TIA for any ideas.
Oscar
Have you restarted the callBridge in order to take the new lic file into account?
After changing license recording, license recording has actived on CMS Core ( host Callbridge). It works fine.
Thanks for your assistance
csrlima
Level 3
Level 3
Hi , i have this same problem:
i have one cms callbridge with lics and xmpp services running , i have one cms recorder and one Windows NFS  and my recorder is not working:
Can someone help me?
IN CMS CALL BRIGDGE SYSLOG :
2018-09-24
16:25:33.787
Recorder "https://10.92.240.205:8443" unavailable
2018-09-24
16:21:58.650
Warning
unable to start recording -- no available recording devices
Sep 24 16:51:08 user.info xpto-cms01 authp:  re-registration from server "xpto-cms01.oil.xptoenergia.corp"
xpto-cms01> xmpp
Enabled                 : true
Clustered               : false
Domain                  : oil.xptoenergia.corp
Listening interfaces    : a
Key file                : webadmin.key
Certificate file        : webadmin.crt
CA Bundle file          : caroot4.crt
Max sessions per user   : unlimited
STATUS                  : XMPP server running
xpto-cms01> license
Feature: callbridge status: Activated expiry: 2118-Jul-25 (36463 days remain)
Feature: turn status: Activated expiry: 2118-Jul-25 (36463 days remain)
Feature: webbridge status: Activated expiry: 2118-Jul-25 (36463 days remain)
Feature: branding status: Activated expiry: 2118-Jul-25 (36463 days remain)
Feature: recording status: Activated expiry: 2118-Jul-25 (36463 days remain)
Feature: shared status: Activated expiry: 2118-Jul-25 (36463 days remain)
xpto-cms01>
xpto-cms01> callbridge
Preferred interface   : none
Address               : none
IN CMS RECORDER SYSLOG :
Sep 24 15:54:13 daemon.info xpto-cmsrec01 recorder-proxy[1]:  2018/09/24 15:54:13 Connection from 10.92.240.207:45444: Failed authentication: [Certificate not in whitelist]
xpto-cmsrec01> recorder
Enabled                 : true
Interface whitelist     : a:8443 lo:8443
Trust bundle            : caroot4.crt
NFS domain name         : 10.92.240.203
NFS directory           : /cmsrec-nfs
xpto-cmsrec01>
i already create dtmf profiles but is not working and i dont see yet record button in cms space
2018-09-24 13:18:57.193 Info call 1222465: unable to start recording (call bfe96e44-5d5a-4c97-ac40-898f25e21cbf) -- recording control not allowed2018-09-24 13:19:01.846 Info resource 0:0 for "guest425329276@oil.xptoenergia.corp"; DTMF entry "*"2018-09-24 13:19:02.250 Info resource 0:0 for "guest425329276@oil.xptoenergia.corp"; DTMF entry "*"2018-09-24 13:19:03.337 Info resource 0:0 for "guest425329276@oil.xptoenergia.corp"; DTMF entry "7"2018-09-24 13:19:04.890 Info resource 0:0 for "guest425329276@oil.xptoenergia.corp"; DTMF entry "#"2018-09-24 13:19:38.832 Info call 1222465: unable to start recording (call bfe96e44-5d5a-4c97-ac40-898f25e21cbf) -- recording control not allowed
Hi, I solved my problem : "unable to start recording -- no available recording devices  " adding my callbridge certificate to recorder trust bundle:
>recorder trust  "callbridge.crt"
cmsrec01> recorder
Enabled                 : true
Trust bundle            : callbridge.crt
cmsrec01>
cms01> callbridge
Address               : none
galp-cms01>
Sep 26 09:03:03 local0.info cmsrec01 -cli:  User admin issued command < syslog follow>: permission granted
Sep 26 09:03:09 daemon.info cmsrec01 recorder-proxy[1]:  2018/09/26 09:03:09 Connection from 10.92.240.207:33385: Authentication succeeded
glad its solved.
